Delete Resources
Important:
Oracle recommends that you not delete high
level resources such as /thesaurus or /redirects.
This section applies to Open Storefront Framework
(OSF).
Oracle also recommends that you back up your configuration before deleting any object. For information, see Back up and restore all application configuration.
To delete a resource, issue the following:
DELETE /gsadmin/v1/cloud/resourcePathwhere resourcePath indicates
the object to be deleted. Both the object indicated by resourcePath and its child objects (if any) are
deleted.
For example, the following endpoint deletes the redirects object
and all its child objects (redirect-group objects
and redirect-entry objects):
DELETE /gsadmin/v1/cloud/redirectsNote:
Deleting the application is not supported. For example, the following endpoint fails with an error:
