Understand System-Generated Object Attributes
The following table lists attributes that the system adds to the configuration of objects imported through the POST, PUT, or PATCH methods.
This section applies to Open Storefront Framework
(OSF).
These attributes are read only. You do not need to include these attributes in any configuration that you import.
| Attribute | Name | Value |
ecr:lastModifiedBy |
user ID |
The user who last modified the search interface. Example:
ecr:lastModified |
time stamp |
The time when the search interface was last modified. Example:
ecr:createDate |
time stamp |
The time when the search interface was created. Example:
