Create a Gift Card Extension and Configure the Webhook
To create a custom integration with a gift card payment gateway, you perform the following steps:
This section applies to Open Storefront Framework
(OSF).
- Create the gateway extension. See Gift card extension details for information specific to this extension.
- Upload the extension to the administration interface.
- Enable the gateway for the sites that require it. Be sure to disable any other gift card payment gateways for those sites.
- Configure the Generic Payment webhook by specifying the gateway URL and the username and password. Note that webhook settings are not site-specific. The configuration you supply applies to all sites that use this webhook.
Gift Card Extension Details
The format
of a payment gateway extension is described in the Create a Credit Card Payment Gateway Integration chapter. For a gift card gateway, the gateway.json file should be similar to the following:
"provider": "Custom Gift Card",
"paymentMethodTypes": ["physicalGiftCard"],
"transactionTypes": {
"physicalGiftCard": ["balanceInquiry", "authorize", "void", "refund"]
"processors" : {
"physicalGiftCard": "genericGiftCard"
}The config.json file should be
"configType": "payment",
"titleResourceId": "title",
"descriptionResourceId": "description",
"instances" : [
"id": "agent",
"instanceName": "agent",
"labelResourceId": "agentInstanceLabel"
"id": "preview",
"instanceName": "preview",
"labelResourceId": "previewInstanceLabel"
"id": "storefront",
"instanceName": "storefront",
"labelResourceId": "storefrontInstanceLabel"
"properties": [
"id": "paymentMethodTypes",
"type": "multiSelectOptionType",
"name": "paymentMethodTypes",
"required": false,
"helpTextResourceId": "paymentMethodsHelpText",
"labelResourceId": "paymentMethodsLabel",
"defaultValue": "physicalGiftCard",
"displayAsCheckboxes": true,
"public": true,
"options": [
"id": "physicalGiftCard",
"value": "physicalGiftCard",
"labelResourceId": "physicalGiftCardPayLabel"
"id": "giftCardMaxLength",
"type": "stringType",
"name": "giftCardMaxLength",
"helpTextResourceId": "giftCardMaxLengthHelpText",
"labelResourceId": "giftCardMaxLengthLabel",
"required": true,
"defaultValue": "19",
"public": true
"id": "giftCardPinRequired",
"type": "booleanType",
"name": "giftCardPinRequired",
"helpTextResourceId": "giftCardPinRequiredHelpText",
"labelResourceId": "giftCardPinRequiredLabel",
"defaultValue": true,
"public": true
"id": "giftCardPinMaxLength",
"name": "giftCardPinMaxLength",
"required": false,
"helpTextResourceId": "giftCardPinMaxLengthHelpText",
"labelResourceId": "giftCardPinMaxLengthLabel",
"defaultValue": "4",
"public": true
"id": "includeOrderInWebhookPayload",
"name": "includeOrderInWebhookPayload",
"helpTextResourceId": "includeOrderHelpText",
"labelResourceId": "includeOrderLabel",
"public": true
}The properties in the config.json file shown above create controls that appear in the Payment
Processing settings in the administration interface. These
controls allow the merchant to specify whether a shopper using a gift
card is required to supply a PIN, as well as the maximum length
of the gift card number and the PIN. The includeOrderInWebhookPayload property creates a checkbox for specifying whether or not
to include the order data in the webhook call.
