Create Inventory Data for Locations
You can use the createInventory endpoint
to set inventory values for a specific SKU at a location.
This section applies to Open Storefront Framework
(OSF).
When you create a new inventory location, it initially has no inventory data associated with it. You can set inventory values for a SKU at the location. For example, the following request specifies inventory data for the location created in the previous section:
POST /ccadmin/v1/inventories HTTP/1.1
Authorization: Bearer <access_token>
"locationId": "Warehouse13",
"id": "xsku5014",
"stockThreshold": 10,
"stockLevel": 75
}The endpoint includes the inventory data in the response body:
"locationInventoryInfo": [
"preorderThreshold": 0,
"availabilityStatus": 1000,
"backorderThreshold": 0,
"availabilityStatusMsg": "inStock",
"backorderLevel": 0,
"preorderLevel": 0,
"skuNumber": null,
"availableToPromise": null,
"translations": null,
"availabilityDate": null,
"inventoryId": null,
"displayName": null,
"stockLevel": 75
"links": [
"rel": "self",
"href": "https://myserver.example.com:7002/ccadmin/v1/inventories"
"skuNumber": "xsku5014",
"skuId": "xsku5014",
"displayName": "Titanium Analog Watch"
}Notice that the response encapsulates the returned inventory data
in a locationInventoryInfo array object. This object
type is used whenever inventory is returned for a non-default location,
and enables returning inventory for multiple locations. (See Retrieve inventory data for locations for an
example of returning inventory for multiple locations.)
Update Inventory for a Location
You can use the updateInventory endpoint to modify the inventory of a specific
SKU at a specific location. You specify the location and the updated
inventory data in the request body. For example:
PUT /ccadmin/v1/inventories/xsku5014 HTTP/1.1
"stockThreshold": 20,
"stockLevel": 200
} Delete Inventory for a Location
You can use the deleteInventory endpoint to delete
the inventory of a specific SKU at a specific location. This endpoint
takes two query parameters:
- A
typequery parameter to specify the item type. The value of this parameter must beproduct(for a product) orvariant(for a SKU). Thedefaultis variant, so if you omit the parameter, Retail Digital Commerce assumes that the item is a SKU. - An optional
locationIdquery parameter to specify the location by its ID.
For example:
DELETE /ccadmin/v1/inventories/xsku5014?locationId=Warehouse13 HTTP/1.1
