Retrieve Inventory Data for Locations
To retrieve inventory at specific locations, you use the getInventory endpoint with the locationIds query parameter.
This section applies to Open Storefront Framework
(OSF).
The locationIds query parameter allows you to
specify one or more location IDs as a comma-separated
list. For example:
GET /ccadmin/v1/inventories/xsku5014?locationIds=Warehouse13,Warehouse11 HTTP/1.1
Authorization: Bearer <access_token>The response includes a locationInventoryInfo array
in which each entry is the inventory for one of the locations specified
in the URL. For example:
"locationInventoryInfo": [
"preorderThreshold": 0,
"stockThreshold": 20,
"availabilityStatus": 1000,
"backorderThreshold": 0,
"availabilityStatusMsg": "inStock",
"backorderLevel": 0,
"locationId": "Warehouse13",
"preorderLevel": 0,
"skuNumber": null,
"availableToPromise": null,
"translations": null,
"availabilityDate": null,
"inventoryId": null,
"displayName": null,
"stockLevel": 200
"stockThreshold": 5,
"locationId": "Warehouse11",
"preorderLevel": 0,
"skuNumber": null,
"stockLevel": 22
"links": [
"rel": "self",
"href": "https://myserver.example.com:7002/ccadmin/v1/inventories/xsku5014?
locationIds=Warehouse13,Warehouse11"
"skuNumber": "xsku5014",
"skuId": "xsku5014",
"displayName": "Titanium Analog Watch"
}You can include inventory for the default inventory location as
well by setting the includeDefaultLocationInventory query parameter to true. For example,
the following call returns inventory for the default location
as well as the Warehouse13 location:
locationIds=Warehouse13&includeDefaultLocationInventory=true HTTP/1.1
Authorization: Bearer <access_token>Note that if you do not use the locationIds parameter
to specify a non-default location, inventory for the default
location is returned. This is the case even if you do
not set includeDefaultLocationInventory to
true. If you do use locationIds, however, inventory for the default location is omitted
unless you explicitly set includeDefaultLocationInventory to true.
Set an inventory record for a SKU using the location’s locationId. For example:
POST /ccadmin/v1/inventories/ HTTP/1.1
// IN STOCK
"id": "Sku_13D",
"type": "variant",
"stockLevel": 3000,
"preorderLevel": 0,
// OUT OF STOCK
"id": "Sku_15DE",
"type": "variant",
"stockLevel": 1,
"preorderLevel": 0,
