Create a Loyalty Point Extension and Configure the Webhook
To create a custom integration with a loyalty point payment gateway, you must create a loyalty point extension and configure the Custom Currency webhook.
This section applies to Open Storefront Framework
(OSF).
To create the integration, you perform the following steps:
- Create the gateway extension, as described below.
- Upload the extension to the administration interface.
- Enable the gateway for the sites that require it.
- Add a loyalty point payment option to the checkout page.
- Configure the Custom Currency webhook by specifying the gateway URL and the username and password. Note that webhook settings are not site-specific. The configuration you supply applies to all sites that use this webhook.
Loyalty Point Extension Details
The format
of a payment gateway extension is described in the Create a Credit Card Payment Gateway Integration chapter. For a loyalty point gateway, the gateway.json file should be similar to the following:
"provider": "Loyalty Points Payment Gateway",
"paymentMethodTypes": ["loyaltyPoints"],
"transactionTypes": {
"loyaltyPoints": ["balanceInquiry", "authorize", "void", "refund"]
"processors" : {
"loyaltyPoints": "loyaltyPoints"
}The config.json file should be
"configType": "payment",
"titleResourceId": "title",
"descriptionResourceId": "description",
"instances" : [
"id": "agent",
"instanceName": "agent",
"labelResourceId": "agentInstanceLabel"
"id": "preview",
"instanceName": "preview",
"labelResourceId": "previewInstanceLabel"
"id": "storefront",
"instanceName": "storefront",
"labelResourceId": "storefrontInstanceLabel"
"properties": [
"id": "paymentMethodTypes",
"type": "multiSelectOptionType",
"name": "paymentMethodTypes",
"required": false,
"helpTextResourceId": "paymentMethodsHelpText",
"labelResourceId": "paymentMethodsLabel",
"defaultValue": "loyaltyPoints",
"displayAsCheckboxes": true,
"public": true,
"options": [
"id": "loyaltyPoints",
"value": "loyaltyPoints",
"labelResourceId": "loyaltyPointsLabel"
"id": "includeOrderInWebhookPayload",
"type": "booleanType",
"name": "includeOrderInWebhookPayload",
"helpTextResourceId": "includeOrderHelpText",
"labelResourceId": "includeOrderLabel",
"defaultValue": true,
"public": true
