Loyalty Point Payment Properties
When the Custom Currency webhook executes, it sends a JSON request body to the payment gateway.
This section applies to OSF. This section applies to Open Storefront Framework (OSF).
The request body contains information about the order, the method of payment, and the type of transaction being initiated. The gateway processes the request and returns a JSON response body that contains information about the results of the transaction, including whether the transaction succeeded.
The set of properties in the request and response bodies, including the subobjects, vary depending on the type of transaction. For loyalty point gateways, there are four transaction types supported: authorize, void, refund, and balance inquiry.
Loyalty Point Payment Request Properties
This section describes the top-level properties and the properties of subobjects sent in the JSON request body of the Custom Currency webhook for loyalty point transactions. Note that if the includeOrderInWebhookPayload property in the gateway extension's config.json file is set to true, the order is also included in the request (except for balance inquiry requests, which do not have an associated order). See Order Submit webhook for information about the order properties.
Top-level properties
The following table describes the top-level properties that Oracle Retail Digital Commerce sends in the webhook request.
Property Description
transactionType
A code indicating the type of transaction. This must be one of the following numeric values:
0100 (authorize)
0110 (void)
0400 (refund)
0600 (balance inquiry)
channel
The area of the system where the payment-processing request originated. Valid values are:
storefront
agent
review
orderId The ID of the order associated with the transaction
currencyCode The custom currency code used for the loyalty program. See Create a custom currency for loyalty points for information about this value.
locale The shopper’s locale, taken from the order. If no locale is set, the default locale from the storefront is used.
customProperties Additional key/value pairs to be sent to the payment provider
paymentId The ID of the internal payment group
transactionId The unique ID of the transaction. Consists of the order ID, the payment ID, and the transaction timestamp (in milliseconds), separated by hyphens.
transactionTimestamp
The timestamp of the transaction, expressed as an ISO 8601 value in the following format:
yyyy-MM-dd'T'HH:mm:ssZ
paymentMethod The payment method. For loyalty points, the value is loyaltyPoints.
amount For authorize, void, and refund transactions, the number of loyalty points, expressed as a positive 12-digit number.
retryPaymentCount The number of times payment has been retried for the order
siteURL The URL of the site on which the order is placed
siteId The ID of the site on which the order is placed
gatewayId The ID of the payment gateway
gatewaySettings Key/value pairs of properties that configure the payment gateway
profile properties
The following table describes the properties of the profile object included in the request. These values are associated with the shopper purchasing the order.
id The Commerce ID of the shopper profile
phoneNumber The phone number from the shopper profile
email The email address from the shopper profile
profileDetails properties
The following table describes the properties of the profileDetails object in the request. These values are associated with the customer purchasing the order.
id The ID of the customer profile
lastName The last name of the customer profile
firstName The first name of the customer profile
middleName The middle name of the customer profile
email The email address from the customer profile
taxExempt Indicates whether the customer tax-exempt status; either true or false
taxExemptionCode For a customer with tax-exempt status, the exemption code
profileType The type of profile; either b2c_user or b2b_user
receiveEmail Indicates whether the customer agrees to receive email; either yes or no
registrationDate
The timestamp of when the profile was created, expressed as an ISO 8601 value in the following format:
lastPasswordUpdate
The timestamp of when the password for the profile was last updated, expressed as an ISO 8601 value in the following format:
loyaltyDetails properties
The following table describes the properties of the loyaltyDetails objects sent in an authorization request or balance inquiry. These values are retrieved from the shopper’s profile.
programName The name of the loyalty program
programId The ID for the loyal program
membershipId The shopper’s membership ID in the loyalty program
status
The shopper’s status in the loyalty program. Valid values are:
RequestForEnrollment
Enrolled
RequestForUnenrollment
Unenrolled
Failed
referenceInfos properties
The following table describes the properties of the referenceInfos objects sent in a void request or refund request. The values of these properties are taken from the original authorization transaction so the merchant can map the void or refund to it.
amount The number of loyalty points used in the original transaction, expressed as a positive 12-digit number.
locale The shopper’s locale from the original transaction
merchantTransactionId The transaction reference ID from the merchant
hostTransactionId The transaction reference ID from the payment gateway
billingAddress properties
The following table describes the properties of the billingAddress object in an authorization request. The billing address is the address of the shopper to whom the order is charged.
lastName The last name of the shopper
postalCode The postal code in the address (for example, the zip code in the United States)
phoneNumber The phone number associated with the address
email The email address associated with the address
state The state in the address
address1 The first line of the address. Typically the street and number
address2 The second line of the address. Included as an empty string in the JSON data if no value exists in the order
firstName The first name of the shopper
city The city in the address
country The country in the address
shippingAddress properties
The following table describes the properties of the shippingAddress object in an authorization or balance inquiry request. The shipping address is the address of the person (not necessarily the shopper) receiving the order.
lastName The last name of the order recipient
address1 The first line of the address. Typically the street and number.
address2 The second line of the address. Included as an empty string in the JSON data if no value exists in the order.
firstName The first name of the order recipient
Sample balance inquiry request
The following is an example of a loyalty point balance inquiry request:
  "loyaltyDetails": [
      "programName": "programForFlyer",
      "membershipId": "member0002",
      "programId": "prg10002",
      "status": "Enrolled"
      "programName": "programForYoungster",
      "membershipId": "member0001",
      "programId": "prg10001",
  "orderId": "o30417",
  "profile": {
    "phoneNumber": "1234512345",
    "id": "110072",
    "email": "john@example.com"
  "channel": "storefront",
  "locale": "en",
  "transactionId": "o30417-pg30418-1504691722253",
  "transactionTimestamp": "2017-09-06T09:55:22+0000",
  "transactionType": "0600",
  "customProperties": {
    "cust-prop2": "cust-prop2",
    "cust-prop1": "cust-prop1"
  "paymentId": "pg30418",
  "gatewaySettings": {
    "paymentMethodTypes": "loyaltyPoints"
  "paymentMethod": "loyaltyPoints",
  "shippingAddress": {
    "lastName": "Niel",
    "country": "US",
    "firstName": "John",
    "address2": null,
    "city": "Cambridge",
    "address1": "1 Main St",
    "postalCode": "02142",
    "state": "MA",
  "siteId": "siteUS",
  "currencyCode": "PTS",
  "gatewayId": "demoLoyaltyPointsPaymentGateway"
Sample authorization request
The following is an example of a loyalty point authorization request:
  "loyaltyDetails": [
  "amount": "000000000200",
  "profile": {
    "id": "110072",
  "profileDetails": {
    "id": "110072",
    "lastName": "Shopper",
    "firstName": "Test",
    "taxExempt": false,
    "profileType": "b2c_user",
    "receiveEmail": "no",
    "registrationDate": "2019-10-15T06:50:51.000Z",
    "lastPasswordUpdate": "2019-10-15T06:50:51.000Z",
  "locale": "en",
  "siteURL": "https://www.example.com",
  "retryPaymentCount": 0,
  "transactionId": "o30417-pg30415-1504691268818",
  "transactionTimestamp": "2019-12-06T09:47:48+0000",
  "transactionType": "0100",
  "paymentId": "pg30415",
    "lastName": "Niel",
    "country": "US",
    "address2": null,
    "state": "MA",
  "siteId": "siteUS",
  "billingAddress": {
    "country": "US",
    "lastName": "John",
    "firstName": "Niel",
    "phoneNumber": "9000054321",
    "city": "San Francisco",
    "address1": "1 Elm St",
    "postalCode": "91333",
    "state": "CA",
    "email": "john.niel@gmail.com"
Loyalty Point Payment Response Properties
This section describes the top-level properties and the properties of subobjects that should be returned in the response body of the Custom Currency webhook for loyalty point transactions.
The following table describes the top-level properties that Retail Digital Commerce expects in the webhook response.
transactionType
A code indicating the type of transaction. This must be one of the following numeric values, and is expected to match the value in the request:
0100 (authorization)
0110 (void)
0400 (refund)
currencyCode The custom currency code used for the loyalty program. This is expected to match the value in the request.
locale The shopper’s locale. This is expected to match the value in the request.
channel The area of the system where the payment-processing request originated. This is expected to match the value in the request.
orderId The ID of the order associated with the payment. This is expected to match the value in the request.
paymentId The ID of the internal payment group. Must match the value from the request.
paymentMethod The payment method. Must match the value from the request. For loyalty points, the value is loyaltyPoints.
transactionId The unique ID of the transaction. Consists of the order ID, the payment ID, and the transaction timestamp (in milliseconds), separated by hyphens. Must match the value from the request.
amount The number of loyalty points used in the transaction, expressed as a positive 12-digit number.
The timestamp of the transaction in Oracle Retail Digital Commerce, expressed as an ISO 8601 value in the following format:
siteId The ID of the site on which the order was placed. Must match the value from the request.
gatewayId The ID of the payment gateway. Must match the value from the request.
authorizationResponse, voidResponse, creditResponse, and inquireBalanceResponse properties
The following table describes the properties of the authorizationResponse, voidResponse, creditResponse, or inquireBalanceResponse object in the webhook response. Only one of these objects is included in each response (the object corresponding to the transaction type; for example, a voidResponse object for a void transaction). All of these object types require the same set of properties. The values of these properties indicate the results of the transaction.
responseCode
The decision from the payment provider as interpreted by the merchant. The acceptable values depend on the transaction type. For an authorization request, the code must be one of the following values:
1000 (success)
4000 (sale complete)
9000 (decline)
For a void request, the code must be one of the following values:
2000 (success)
8000 (decline)
For a credit (refund) request, the code must be one of the following values:
3000 (success)
7000 (decline)
For a balance inquiry, the code must be one of the following values:
5000 (success)
6000 (decline)
responseDescription Information from the payment gateway about the response
responseReason Information about why the transaction succeeded or failed
merchantTransactionTimestamp The timestamp of the transaction from the merchant (in milliseconds). Required.
hostTransactionTimeStamp The timestamp of the transaction from the gateway (in milliseconds)
additionalProperties Key/value pairs for additional properties sent by the merchant. (For an authorizationResponse object, we recommend including the programId, programName, and membershipId properties, so they can be included in any subsequent void or refund webhook requests.)
customPaymentProperties A list of the properties from the additionalProperties map that should be returned to the storefront
loyaltyPrograms properties
The following table describes the properties of the objects in the loyaltyPrograms array of an inquireBalanceResponse object.
membershipType The category or level of the membership; for example, silver, gold, or platinum
pointsBalance The number of points available
pointsType The type of points. This should match the currencyCode value described in Create a custom currency for loyalty points.
additionalProperties Key/value pairs for additional properties sent by the merchant for this program type
loyaltyPointDetails properties
The following table describes the properties of the objects in the loyaltyPointDetails array of a loyaltyPrograms object of an inquireBalanceResponse object.
programId The ID of the loyalty program
membershipId The shopper’s ID in the loyalty program
additionalProperties Key/value pairs for additional properties sent by the merchant for this point type
status
The status of the shopper in the loyalty program. Valid values are:
Enrolled
Unenrolled
Failed
Sample balance inquiry response
The following is an example of a response to a loyalty point balance inquiry request:
  "siteId": "siteUS",
  "locale": "en",
  "inquireBalanceResponse": {
    "hostTransactionTimestamp": "1504691722267",
    "responseReason": "inquireBalanceResponseReason",
    "customPaymentProperties": [
      "cust-prop2",
      "cust-prop1"
    "responseDescription": "inquireBalanceResponseDescription",
    "loyaltyPrograms": [
        "loyaltyPointDetails": [
            "membershipType": "blue",
            "pointsBalance": "2000",
            "pointsType": "bluePoints",
            "additionalProperties": {
              "propertyName1": "value1",
              "propertyName2": "value2"
            "membershipType": "red",
            "pointsBalance": "6000",
            "pointsType": "redPoints",
              "propertyName4": "value4",
              "propertyName3": "value3"
            "membershipType": "standard",
            "pointsType": "PTS",
              "propertyName6": "value6",
              "propertyName5": "value5"
          "validTill": "2029-11-26T15:57:55.631Z",
          "validFrom": "2017-07-14T15:57:55.631Z"
            "membershipType": "silver",
            "pointsType": "rewardPoints",
              "propertyName7": "value7",
              "propertyName8": "value8"
            "membershipType": "gold",
            "pointsType": "skyMiles",
              "propertyName10": "value10",
              "propertyName9": "value9"
          "validTill": "2030-12-26T15:57:55.631Z",
          "validFrom": "2017-06-14T15:57:55.631Z"
    "merchantTransactionId": "MERCH-TX-1504691722267",
    "hostTransactionId": "HOST-TX-1504691722267",
      "cust-prop1": "cust-prop1",
    "responseCode": "5000",
    "merchantTransactionTimestamp": "1504691722267"
Sample authorization response
The following is an example of a response to a loyalty point authorization request:
  "authorizationResponse": {
    "hostTransactionTimestamp": "1504691269627",
    "responseReason": "authResponseReason",
      "programName",
      "membershipId",
      "programId"
    "responseDescription": "authResponseDescription",
    "merchantTransactionId": "MERCH-TX-1504691269627",
    "hostTransactionId": "HOST-TX-1504691269627",
    "responseCode": "1000",
    "merchantTransactionTimestamp": "1504691269627"
  "locale": "en",
  "transactionTimestamp": "2017-09-06T09:47:48+0000",
  "siteId": "siteUS",
