Create a Site
You can use the createSite endpoint to
create a new site, using the default site as a template.
This section applies to Open Storefront Framework
(OSF).
For example:
POST /ccadmin/v1/sites HTTP/1.1
Authorization: Bearer <access_token>
x-ccasset-language: en
"properties":
"productionURL": "www.example2.com"
The response is similar to the following:
"longDescription": null,
"priceListGroupList": [
"deleted": false,
"repositoryId": "defaultPriceGroup",
"active": true,
"id": "defaultPriceGroup"
"productionURL": "www.example2.com",
"timezone": "etc_utc",
"description": null,
"secondaryCurrency": null,
"defaultCatalog": {
"displayName": "Product Catalog",
"repositoryId": "cloudCatalog",
"id": "cloudCatalog"
"requireGDPRP13nConsent": false,
"type": "siteConfiguration",
"defaultBillingCountryId": null,
"defaultShippingCountryId": null,
"enabled": false,
"requireGDPRCookieConsent": false,
"payTaxInSecondaryCurrency": false,
"timeToLive": null,
"defaultLocaleId": "1",
"activeTheme": null,
"loyaltyPrograms": [
"paymentOption": "0",
"additionalProductionURLs": [
"links": [
"rel": "self",
"href": "http://myserver.example.com:7002/ccadmin/v1/sites"
"id": "100002",
"defaultSite": false,
"additionalLocaleIds": [
"recommendationsHost": "pt-recs-app1.us.example.com",
"favicon": null,
"allowedOriginMethods": {
"noimage": null,
"defaultPriceListGroup": {
"deleted": false,
"active": true,
"payShippingInSecondaryCurrency": false,
"siteTypes": [
"Retail Digital Commerce"
"recommendationsPort": "8080",
"shipFromAddress": {
"repositoryId": "100002",
"name": "100002"
If you want to implement wish lists on a new site that you
create using the Admin API, you must also create a new wish
list environment and associate it with the site. To do this,
use the PUT /swm/rs/v1/sites/cc/{ccSiteId} endpoint
in the Social Wish Lists API. If you subsequently modify
the site using the Admin API, you should use this endpoint
to make the equivalent changes to the associated wish list
environment. If you delete the site, you should also delete the
associated wish list environment, using the DELETE
/swm/rs/v1/sites/cc/{ccSiteId} endpoint.
For more information about these endpoints, see the REST API documentation that is available through the Oracle Help Center:
http://docs.oracle.com/cloud/latest/commercecs_gs/CXOCC/
createSiteFromForm endpoint
In addition to the createSite endpoint, which creates a site based on the
default site, Retail Digital Commerce includes a createSiteFromForm endpoint
that creates a site based on a site you specify. For example, to create a new site using site
100002 as a template:
POST /ccadmin/v1/sites/100002 HTTP/1.1
"properties":
"productionURL": "www.example3.com"
