Update a Site
You can use the updateSite endpoint to modify settings on an existing site.
This section applies to OSF . This section applies to Open Storefront Framework (OSF).
For example:
PUT /ccadmin/v1/sites/100002  HTTP/1.1
Authorization: Bearer <access_token>
x-ccasset-language: en
  "properties":
    "productionURL": "www.example7.com",
    "defaultLocaleId": "3"
The response is similar to the following:
   "longDescription": null,
   "priceListGroupList": [
         "deleted": false,
         "repositoryId": "defaultPriceGroup",
         "active": true,
         "id": "defaultPriceGroup"
   "timezone": "etc_utc",
   "description": null,
   "secondaryCurrency": null,
   "defaultCatalog": {
      "displayName": "Product Catalog",
      "repositoryId": "cloudCatalog",
      "id": "cloudCatalog"
   "requireGDPRP13nConsent": false,
   "type": "siteConfiguration",
   "defaultBillingCountryId": null,
   "defaultShippingCountryId": null,
   "enabled": false,
   "requireGDPRCookieConsent": false,
   "payTaxInSecondaryCurrency": false,
   "timeToLive": null,
   "defaultLocaleId": "3",
   "activeTheme": null,
   "loyaltyPrograms": [
   "paymentOption": "0",
   "additionalProductionURLs": [
   "links": [
         "rel": "self",
         "href": "http://myserver.example.com:7002/ccadmin/v1/sites/100002"
   "id": "100002",
   "defaultSite": false,
   "additionalLocaleIds": [
   "recommendationsHost": "pt-recs-app1.us.example.com",
   "favicon": null,
   "allowedOriginMethods": {
   "noimage": null,
   "defaultPriceListGroup": {
      "deleted": false,
      "active": true,
   "payShippingInSecondaryCurrency": false,
   "siteTypes": [
      "Retail Digital Commerce"
   "recommendationsPort": "8080",
   "shipFromAddress": {
   "repositoryId": "100002",
   "name": "100002"
