Delete a Site
You can use the deleteSite endpoint to
delete an existing site.
This section applies to Open Storefront Framework
(OSF).
For example:
DELETE /ccadmin/v1/sites/100002 HTTP/1.1
Authorization: Bearer <access_token>
If the site is deleted successfully, a 200-level HTTP status code is returned.
Note that you cannot delete the default site. If you want to delete the site that is currently the default, first make a different site the default.
