21 Implement Single Sign-On for Internal Users
You can configure Oracle Identity Cloud Service (IDCS) to enable the Retail Digital Commerce administration interface to support single sign-on (SSO) with other Oracle Cloud applications.
Two single sign-on implementations are supported, OpenID Connect and SAML 2.0. Note that OpenID Connect SSO supports the use of IDCS OAuth 2 application keys with Retail Digital Commerce, to simplify integration with other Oracle applications. SAML 2.0 SSO does not support this.
