Renew your SAML 2.0 SSO Certificate
Your SAML certificate is valid for a period of time determined by your Identity Provider. An administrator at your store should keep track of when your SAML certificate is due to expire, and renew the certificate in advance.
This section applies to Open Storefront Framework
(OSF).
To check the expiration date on your certificate, use the
getSamlSettings endpoint in the Admin
API:
GET /ccadmin/v1/merchant/samlSettings HTTP/1.1
Authorization: Bearer <access_token>The response includes a certificate object with
startDate and endDate properties. The endDate property
indicates when the certificate will expire:
"nameIdPolicyFormat": "urn:oasis:names:tc:SAML:2.0:nameid-format:persistent",
"requireEncryptedAssertions": false,
"requireSignedResponse": false,
"certificate": {
"endDate": "2021-12-14T18:16:00.000Z",
"startDate": "2020-12-15T18:16:00.000Z"
"signAuthnRequest": true,
"spMetadata": "<service provider entity descriptor>",
"links": [
"rel": "self",
"href": "http://www.example.com:7002/ccadmin/v1/merchant/samlSettings"
"nameIdPolicyAllowCreate": true,
"enabled": false
}If your certificate will be expiring soon, use the
renewSamlCertificate endpoint to renew it, Note
that the request body should be empty:
POST /ccadmin/v1/merchant/renewSamlCertificate HTTP/1.1
Authorization: Bearer <access_token>If the request succeeds, the response has a status code of 200 to indicate the certificate has been renewed. The response payload includes the start date and end date for the new certificate:
"endDate": "2022-12-10T17:41:09.000Z",
"links": [
"rel": "self",
"href": "http://www.example.com:7002/ccadmin/v1/merchant/renewSamlCertificate"
"startDate": "2021-12-11T17:41:09.000Z"
If the request is accepted but certificate renewal is still in
progress, the response has a status code of 202. You can
use the getSamlSettings endpoint later
to check whether the certificate has been successfully renewed.
After you renew the certificate, be sure to upload the new certificate to your Identify Provider to replace the old one.
