Machine Learning for Search
Retail Digital Commerce can identify popular products associated with popular searches based on a number of factors, including shopper behavior and purchasing history, trend analysis, and view data, and automatically generate a corresponding set of ranking rules that boost these products in the related search results.
This section applies to Open Storefront Framework
(OSF).
The machine-learning feature works in conjunction with dynamic curation and search relevancy. Manually-boosted products take precedence, followed by products identified by machine learning, with all remaining products ordered by relevancy and dynamic-curation criteria.
This feature affects only keyword search results and any subsequent navigation. It does not affect pages that contain only navigation results.
Understand Auto-generated Ranking Rules
When the feature is enabled,
Retail Digital Commerce periodically uploads the auto-generated popular
products ranking rules to the /system/rankingRules endpoint under internal-keywords. You can view
the auto-generated ranking rules by querying the following endpoint:
GET /gsadmin/v1/cloud/content/system/rankingRules/internal-keywordsImportant:
Do not attempt to modify the internal-keywords auto-generated ranking rules. Retail Digital Commerce will overwrite your changes.
The auto-generated popular products ranking rules take effect in your production environment whenever changes are published.
Only Boost/bury rules have higher precedence than the auto-generated popular products ranking rules. Popular products ranking rules take precedence over the default Relevancy ranking, Dynamic Curation, and static ranking rules.
Enable Auto-generated Popular Products Ranking Rules
To enable this feature, you must use the Admin API:
- Run
GET /gsadmin/v1/cloud/configuration/services/internal-keywords. - If
boostDisabledis present in the response and set totrue, then set it tofalse. - Issue a
PUTcommand to/gsadmin/v1/cloud/configuration/services/internal-keywordsto save your modifications.
Changes will take affect once the overnight process has run.
Disable Auto-generated Popular Products Ranking Rules
To disable this feature, you must use the Admin API:
- Run
boostDisabledis present in the response and set tofalse, then add it if necessary and set it totrue. - Issue a
PUTcommand to/gsadmin/v1/cloud/configuration/services/internal-keywordsto save your modifications. - Issue a
DELETEcommand to/gsadmin/v1/cloud/content/system/rankingRules/internal-keywordsto delete previous rules.
Identify Promoted Products
To identify when products have been promoted,
you can access your site using the Preview environment and inspect
the underlying ccstore/v1/search endpoint call. Each
promoted product includes an additional property of DGraph.RankLabel.bstratify.merch.
