Search Non- Catalog Data
You can index and search data that is not part of the product catalog.
This section applies to Open Storefront Framework
(OSF).
For example, you may want the Help page on your site to be included in a search. If a customer searches for “help”, the Help page is returned along with any products that match. Note the Help page will be returned in addition to the matching product catalog results.
To index and search additional data, you must take the following steps:
- Set up the search attributes by performing the following:
- Add attributes using Attributes API
The properties/dimensions used for adding records to newly created record collections, are either already defined in the application or can be imported manually using
/gsadmin/v1rest end-point. - Add attributes to Search interface using Search Interface API
- Create page definition with record filter
- Update the index by taking the following steps:
- Upload records using the Search Data API endpoints
- Manually Trigger Baseline/Partial update
- Query the index by doing the following:
Make request to new page.
Create a Data Record Collection
You use REST endpoints
exposed at /gsdata/v1/cloud/data/{recordCollection} to create / populate a data record collection.
POST /gsdata/v1/cloud/data/{recordCollection}
Content-Type: application/vnd.oracle.resource+json; type=collection - if creating/updating bulk of records
<json data>recordCollection- A valid record collection name, as defined by the regular expression[a-zA-Z][a-zA-Z0-9_-]*. CAShas a limitation that therecordStorename cannot have more than 128 characters.
Example: Import records to the record collection
You can use the following call to import the specified records to the record collection.
POST /gsdata/v1/cloud/data/storeLocations
"Content-Type: application/vnd.oracle.resource+json; type=collection"
links :[{
"rel" : "self",
"href" : "/gsdata/v1/cloud/data/storeLocations"
items : [
"record.action": "deleteAll"
links :[{
"rel" : "self",
"href" : "/gsdata/v1/cloud/data/storeLocations/store1000"
"record.id": "store1000",
"record.action": "upsert",
"store.state": "CA",
"store.amenities": [
"Coffee Shop",
"Pharmacy"
"record.action": "delete",
"record.id": "store1011"
} Use Case: Search Buying Guides
For the sample store, Company A has a range of cameras and camcorders for sale. To help their customers find the right camera, they have some buying guides that walk through the features, and they want to include summary information on this so the information are returned along with the products when relevant.
- Call the
gsdataendpoint to create the new buying guide items.The following are sample data representing two of these buying guides:
First they upload the following JSON to the server using the new{ "content.type": "buyingGuide", "guides.department": "Electrical", "guides.productType": "DSLR Cameras", "guides.keywords": "DSLR, Camera, Professional, Zoom, interchangeable lens", "record.locale": "en-US", "record.id": "guide1001", "guides.description": "Looking for more information on our DSLR cameras? Read on to learn how to pick the right camera for you." }, { "content.type": "buyingGuide", "guides.department": "Electrical", "guides.productType": "Compact Cameras", "guides.keywords": "compact, camera, holiday, small, point-and-shoot, automatic", "record.locale": "en-US", "record.id": "guide1002", "guides.description": "Looking for a compact camera to take on holiday? We compare the best compacts!" }gsdataendpoint. They use POST to create a new resource, and use the syntax of/gsdata/v1/cloud/data/buyingGuides, wherebuyingGuidesis the name for the new entry.POST /gsdata/v1/cloud/data/buyingGuides { "items": [{ "content.type": "buyingGuide", "guides.department": "Electrical", "guides.productType": "DSLR Cameras", "guides.keywords": "DSLR, Camera, Professional, Zoom, interchangeable lens", "record.locale": "en-US", "record.id": "guide1001", "guides.description": "Looking for more information on our DSLR cameras? Read on to learn how to pick the right camera for you." }, { "content.type": "buyingGuide", "guides.department": "Electrical", "guides.productType": "Compact Cameras", "guides.keywords": "compact, camera, holiday, small, point-and-shoot, automatic", "record.locale": "en-US", "record.id": "guide1002", "guides.description": "Looking for a compact camera to take on holiday? We compare the best compacts!" }, { "record.action": "OCCForceFlush" }] } - They create new attributes.
After the data have been created, they define the attributes that were used. To do this, they use the standard Attributes API, and use POST to create new attributes corresponding to the data they uploaded previously. This is the code to create new attributes of:
guides.department(as a facet)guides.productType(as a searchable property)guides.description(as a searchable property)content.type(as a filterable property)
POST /gsadmin/v1/cloud/attributes/system/guides.department { "ecr:lastModifiedBy": "admin", "ecr:type": "dimension", "isAutogen": true } POST /gsadmin/v1/cloud/attributes/system/guides.productType { "ecr:lastModifiedBy": "admin", "ecr:type": "property", "isRecordSearchEnabled": true } POST /gsadmin/v1/cloud/attributes/system/guides.description { "ecr:lastModifiedBy": "admin", "ecr:type": "property", "isRecordSearchEnabled": true } POST /gsadmin/v1/cloud/attributes/system/content.type { "ecr:lastModifiedBy": "admin", "ecr:type": "property", "isRecordFilterable": true } - They create new services using the pages endpoint, and add the
new fields as being returned.
They want to define a separate endpoint that they can call to return this information. This is done using the Pages Admin API. They name the page “
buyingGuide”, and define that they want to return four properties:guides.descriptionguides.productTypeguides.departmentrecord.idPOST /gsadmin/v1/cloud/pages/Default/buyingGuide { "contentType": "Page", "ecr:type": "page", "contentItem": { "@name": "Content Search Service", "@type": "GuidedSearchService", "@appFilterState": { "@type": "FilterState", "recordFilters": [ "content.type:buyingGuide" ] }, "navigation": { "@type": "NavigationContainer", "contentPaths": [ "/content/facets" ] }, "resultsList": { "@type": "ResultsList", "fieldNames": [ "guides.description", "guides.productType", "guides.department", "record.id" ], "rankingRules": { "merchRulePaths": [ "/content/rankingRules" ], "systemRulePaths": [ "/content/system/rankingRules" ], "systemRuleLimit": 10 } }, "searchAdjustments": { "@type": "SearchAdjustments" } } } - Add the properties created above to the “All” search interface.
- Add the searchable attributes they have just added to the “All”
searchable field ranking. To do this:
- Open the Oracle Retail Digital Commerce administration interface.
- Click to open the Search section.
- Click Searchable Field Rankings.
- Click All.
- Use the dropdown to add the new attributes to the end of the list,
in this order:
guides.departmentguides.productTypeguides.description
- Index the data. They use the following API endpoint to run a search
index to update the data:
POST /ccadmin/v1/search/index?op=baselineThey monitor the progress of this using:
GET /ccadmin/v1/searchWhen
success: trueis displayed, the indexing has completed. - Verify that this works correctly. Query the data by calling the
following URL on their storefront:
/ccstore/v1/assembler/pages/Default/services/buyingGuide?Ntt=camera
Create a Widget to Support Searching Data
Custom product listing widget can support searching data that is not part of the product catalog. For detailed information about creating widgets, see Create a Widget.
Create the widget structure for the product listing sample widget
Widgets that include user interface elements must include display templates. The following shows an example of the files and directories in a product listing widget.
Widget/
ext.json
widget/
ProductistingForAdditionalContent
widget.json
js/
product-listing.js
less/
widget.less
locales/
en/
ns.multicart.json
templates/
display.template
paginationControls.templateThe JavaScript
code you write extends the createsearchViewModel class.
For more information about the widget structure and the contents of
the ext.json and widget.json files, see Understand widgets .
Create the JavaScript file for the product listing sample widget
The widget’s JavaScript file includes functions that let shoppers search data that is not part of the product catalog.
The following example shows
sample JavaScript that implements the createsearch functionality:
////Non-catalog content
widget.assemblerPagesPath = "services/storeLocations"; //This should be services/searchService
widget.ntk = "stores"; //This should point to the search interface created
//Created a function to process the non-catalog content to display them
widget.amenitiesToText = function(obj){
var amenitiestext = obj[0];
for(var i=1; i < obj.length; i++ ){
amenitiestext = amenitiestext + ", " +obj[i];
return amenitiestext;
///////End non-catalog content }Create template files for the product listing sample widget
The widget’s display.template file contains the following code for
rendering the page (the following is an excerpt of the display.template):
<!-- ko if: (listingViewModel().display) -->
<div id="CC-productListing" role="alert">
<!-- ko if: listType() == 'search' -->
<!-- ko with: listingViewModel -->
<div class="sr-only" data-bind="text :pageLoadedText"></div>
<!-- /ko -->
<!-- /ko -->
<div id="CC-product-listing-controls" class="row">
<div class="col-sm-12">
<!-- ko if: $parent.listType() == 'search' -->
<h2 id="search-results" class="sr-only" role="alert" data-bind="widgetLocaleText: 'searchResultsText'"></h2>
<!-- /ko -->
<!-- ko if: titleText -->
<div class="row">
<div class="col-xs-12">
<h2 id="cc-product-listing-title" data-bind="text: titleText"></h2>
</div>
</div>
<!-- /ko -->
<!-- ko if: noSearchResultsText -->
<div class="row">
<div id="cc-productlisting-noSearchResults" class="col-xs-12">
<span data-bind="text: noSearchResultsText"></span>
</div>
</div>
<!-- /ko -->
<!-- ko if: suggestedSearches().length > 0 -->
<div id="cc-productlisting-didYouMean">
<span data-bind="widgetLocaleText:'didYouMeanText'"></span>
<div id="cc-productlisting-didYouMeanTerms" data-bind="foreach : suggestedSearches">
<a data-bind="attr: {id: 'cc-productlisting-didYouMean-Suggestion-'+$index()}, widgetLocaleText: {value:'dYMTermAriaLabel', attr:'aria-label'}, click: $data.clickSuggestion" href="#">
<!-- ko if: ( $index() < ($parent.suggestedSearches().length - 1)) -->
<span data-bind="widgetLocaleText : {value:'dYMTermTextHasNext', attr:'innerText', params: {label: $data.label}}"></span>
<!-- /ko -->
<!-- ko if: ( $index() == ($parent.suggestedSearches().length - 1)) -->
<span data-bind="widgetLocaleText : {value:'dYMTermText', attr:'innerText', params: {label: $data.label}}"></span>
<!-- /ko -->
</a>
</div>
</div>
<!-- /ko -->
Pro <!-- /ko -->
<!-- /ko -->
<!-- ko if: (listingViewModel().totalNumber() > 0) -->
<div data-bind="text: resultsText" class="sr-only" role="alert"></div>
<h3 class="sr-only" role="alert" data-bind="widgetLocaleText: 'viewingOptionsText'"></h3>
<!-- /ko -->
<div class="row">
<div class="col-sm-12" id="cc-area-controls">
<div class="row">The widget’s display.template calls another template file, paginationControls.template. This template file contains
the following code for rendering multiple pages when the list of products
is long:
<div class="btn-group">
<a class="btn btn-default" data-bind="ccNavigation: '', attr : {href: firstPage()}, widgetLocaleText : {value:'goToFirstPageText', attr:'aria-label'}, css: { disabled: $data.currentPage() == 1 }" ><span data-bind="widgetLocaleText: 'goToFirstPagePaginationSymbol'"></span></a>
<a href="#" class="btn btn-default" data-bind="ccNavigation: '', attr: {href: previousPage()}, widgetLocaleText : {value:'goToPreviousPageText', attr:'aria-label'}, css: { disabled: $data.currentPage() == 1 }" rel="prev"><span data-bind="widgetLocaleText: 'goToPreviousPagePaginationSymbol'"></span></a>
<!-- ko foreach: pages -->
<a href="#" class="btn btn-default" data-bind="ccNavigation: '', attr: {href: $parent.goToPage($data)}, css: {active: $data.pageNumber===$parent.currentPage() }">
<!-- ko if: $data.selected === true -->
<span class="sr-only" data-bind="widgetLocaleText : 'activePageText'"></span>
<!-- /ko -->
<!-- ko if: $data.selected === false -->
<span class="sr-only" data-bind="widgetLocaleText : 'goToPageText'"></span>
<!-- /ko -->
<span data-bind="ccNumber: $data.pageNumber"></span>
</a>
<!-- /ko -->
<a href="#" class="btn btn-default" data-bind="ccNavigation: '', attr: {href: nextPage()}, widgetLocaleText : {value:'goToNextPageText', attr:'aria-label'}, css: { disabled: currentPage() == $data.totalNumberOfPages() }" rel="next"><span data-bind="widgetLocaleText: 'goToNextPagePaginationSymbol'"></span></a>
<a href="#" class="btn btn-default" data-bind="ccNavigation: '', attr: {href: lastPage()}, widgetLocaleText : {value:'goToLastPageText', attr:'aria-label'}, css: { disabled: currentPage() == $data.totalNumberOfPages() }"><span data-bind="widgetLocaleText: 'goToLastPagePaginationSymbol'"></span></a>
</div>
