Command-Line Interface
Retail Digital Commerce provides a command-line interface (CLI) that you can use to manage your local workspace.
The CLI provides tools that you can use to create, configure, build, run, deploy, check deployment status and logs, and sync workspaces. Note that if you have multiple workspaces, each workspace has its own matching version of the CLI (the version that was used to create the workspace).
