3 Set Up a Development Environment
You can set up an environment for developing OSF applications on your local workstation.
This chapter describes how to set up an Retail Digital Commerce local storefront development environment using a provided accelerator template. It assumes that you have already read Understand the Open Storefront Framework and are familiar with the OSF architecture.
Once you have set up your environment, you can make a copy of the template and use it as a starting point for building your own application. This process is described in Develop and Deploy Applications.
