Install Required Software
Before you can set up your development environment, you must install certain third-party software tools.
In addition to software supplied by Oracle, a storefront development environment requires the following:
  • Node.js – Install the most recent LTS (long-term support) version of Node.js 18.x on your system. (Do not install a different major version number.) Node.js 18.x is available at:
    https://nodejs.org/dist/latest-v18.x
    The Node.js installation also includes npm.
  • Yarn – Install the latest stable version of Yarn 1.x on your system. (Do not install Yarn 2.x). Yarn 1.x is available at:
    https://legacy.yarnpkg.com/docs/install
