One to One Port Mapping
(Static Server Mode)
This is where there is one Xstore or Xstore Mobile client served from the Jetty instance. It will divert all requests to a single port pairing that is managed inside the EFTLink Server instance. If another POS client is configured to use the same port pairing, it will potentially be blocked out until the port pair becomes free. In this mode, EFTLink Server will allow a single device to use many PEDs through the PED pooling functionality. EFTLink Server does not support load balancing of requests through one port pair so this configuration is not recommended if there are many Xstore mobile clients in the store solution.
If this configuration is suitable then the Xstore Mobile configuration is identical to the standard Xstore configuration. The 'communicatorHosts' parameter is used to set the channel 0 URL and 'deviceCommChannel' is used to set the channel 1 URL, as illustrated below. In this configuration when Xstore or Xstore Mobile starts an authorization request, EFTLink will process the authorization request in the expected way, or if PED pooling is enabled, it will send a list of available PEDs for an associate to choose. Once the associate has chosen a PED, the authorization will proceed in the expected way.
<AuthProcess name="EFT_LINK_HOST" Abstract="true">
<Parameter name="communicatorHosts">
<param_value dtype="List">
<Host dtype="String">socket://localhost:10100;timeout=1000</Host>
</param_value>
</Parameter>
<Parameter name="deviceCommChannel" value="socket://localhost:10101" />
<Parameter name="additionalWorkstationHostsMap">
<param_value dtype="Map">
<MapEntry>
<key dtype="Integer">1</key> <!-- workstation id -->
<value dtype="EFTLinkCommunicationChannels">
<Channel0 dtype="String">socket://localhost:10110</Channel0>
<Channel1 dtype="String">socket://localhost:10111</Channel1>
</value>
</MapEntry>
<MapEntry>
<key dtype="Integer">2</key> <!-- workstation id -->
<Channel0 dtype="String">socket://localhost:10120</Channel0>
<Channel1 dtype="String">socket://localhost:10121</Channel1>
</value>
</MapEntry>
</param_value>
</Parameter>
</AuthProcess>
