Xstore Set Up
As noted above, each POS must use a unique pair of ports for its connection to EFTLink. Also, the POS is configured to access a remote EFTLink rather than a local one.
There are two different ways that Xstore can be set up to use with EFTLink in Server Mode.
One to One Port Mapping (applies to both Xstore and Xstore Mobile)
One to Many Port Mapping (applies to both Xstore and Xstore Mobile)
All configurations illustrated below are part of the Xstore AuthConfig.xml configuration file.
