EFTLink Server (PED Pooling)
Many-to-many mapping between POS and payment system/terminal. Each POS is assigned a dedicated pair of sockets (channels 0 and 1) that connect to a multiplexer/switch. The multiplexer applies configured routing rules and, where required, interacts with the POS associate to determine which EFTLink instance should process the request.
Figure 2-2 EFTLink Server - PEDPool Remote Mode
The diagram above shows EFTLink Server running three EFTLink instances that serve four clients. Three of the clients are communicating directly to EFTLink using TCP sockets, while the fourth client uses WebSocket communication and therefore requires the EFTLink Rest API service to translate requests and responses between the Rest Client and EFTLink.
An example (Snippet) layout of how each configuration file would be as follows:
EFTLink Installation root & Xstore
(Not applicable for communication over websockets)
EFTLinkConfig.properties
ServerChannel0 = 10100
PEDPoolEnabled = true
PEDPoolOneCatchAllChannel0 = true
NumServers = 3
server1.description = EFT1
server2.description = EFT2
server3.description = EFT3
NumClients = 4
pos1.description = Desktop POS 1
pos2.description = Desktop POS 2
pos3.description = Desktop POS 3
pos30.description = Tablet POS 31
pos1.subpool = EFT1, EFT2, EFT3, EFT4
pos2.subpool = EFT1, EFT2, EFT3, EFT4
pos3.subpool = EFT1, EFT2, EFT3, EFT4
pos30.subpool = EFT1, EFT2, EFT3, EFT4
Xstore (ws 1 - ws3)
AuthConfig.xml
<Host dtype="String">socket://localhost:10110</Host>
Server 1
EPSCore0 = oracle.eftlink.opiretail.OPIRetailCore
opiretail.properties
EPSAddress = 192.168.1.11
EPSPort = 8443
Server 2
EPSAddress = 192.168.1.12
EPSPort = 8443
Server 3
LineDisplayEnabled=false
EPSAddress = 192.168.1.13
EPSPort = 8443
Server 4
EPSCore1 = oracle.eftlink.paypal.PayPalCore
LineDisplayEnabled=true
DelegateLineDisplay = true
LineDisplayDelegateList = 0
EwalletCore = 1
EFTLink-rest-api.properties
NumServers = 3
pos1= 10110
pos2 = 10120
pos3 = 10130
pos30 = 10140
EPSAddress = 192.168.1.14
EPSPort = 8443
