BI Response Layout
This section defines various response layouts that will be referenced in the following section when describing required response analyses for each report.
BI Simple Metric
| Column | Property | Type | Required | Description |
0 |
Metric Name |
String |
Y |
Name of the metric. |
1 |
Metric Value |
Number |
Y |
Value of the metric. |
2 |
Value Format |
String |
N |
Format for the value. The following formats are supported:
3 |
Value Label |
String |
N |
An additional label to display below the value. |
BI Metric
0 |
Metric Name |
String |
Y |
1 |
Metric Value |
Number |
Y |
2 |
Value Format |
String |
N |
3 |
Value Label |
String |
N |
An additional label to display below the value |
4 |
Indicator |
String |
N |
An indicator to display next to the value. The supported options are "up", "down", "normal", "info", "important", and "critical". |
BI Metric Chart Config
0 |
Chart Type |
String |
Y |
Type of chart to display: "line", "bar", "area", or "total" |
1 |
Chart Title |
String |
N |
Title to display above chart |
2 |
Render Tooltips |
Boolean |
N |
Hide or show tooltips on the chart. Default true. |
3 |
Series Name |
String |
N |
Label displayed in tooltip. Applies to line, bar, and area charts. |
4 |
Value Format |
String |
N |
Formats the output of values in the chart. Takes the same values as for metrics items. |
5 |
Value Label |
String |
N |
Prefix for values. Applies to total charts only. |
6 |
Value Units |
String |
N |
Suffix for values. Applies to total charts only. |
7 |
X-Axis Title |
String |
N |
Label for the X-axis. Applies to line, bar, and area charts. |
8 |
Render X-Axis Labels |
Boolean |
N |
Show or hide tick labels on the X-axis. Applies to line, bar, and area charts. |
9 |
Y-Axis Title |
String |
N |
Label for the Y-axis. Applies to line, bar, and area charts. |
10 |
Render Y-Axis Labels |
Boolean |
N |
Show or hide tick labels on the Y-axis. Applies to line, bar, and area charts. |
11 |
Initial Scrolling Position |
String |
N |
Which end of the chart to start at if there are too many items to show at once. Options are "first" and "last", defaults to "first". Applies to line, bar, and area charts. |
BI Metric Chart Item
Each BI Metric Chart Item represents a value displayed in a chart (bar, line, area, total).
0 |
Item Value |
Number |
Y |
Value of the item. |
1 |
Item Name |
String |
Y |
Name of the item. |
2 |
Item Series |
String |
Y |
Series Name of the item. |
BI Table Config
0 |
Report Name |
String |
Y |
Name of the report. |
1 |
Image Column Header Label |
String |
N |
Column header label for images. |
2 |
Descriptor 1 Name |
String |
Y |
Column header label for first descriptor. |
3 |
Descriptor 2 Name |
String |
N |
Column header label for second descriptor. |
4 |
Metric 1 Name |
String |
Y |
Column header label for first metric. |
5 |
Metric 1 Value Format Code |
String |
Y |
Value format code for first metric. |
6 |
Metric 1 Max Threshold |
Number |
N |
Metric 1 values greater than the Metric 1 Max Threshold value will be displayed in Green. |
7 |
Metric 1 Min Threshold |
Number |
N |
Metric 1 values less than the Metric 1 Min Threshold value will be displayed in Red. |
8 |
Metric 2 Name |
String |
Y |
Column header label for second metric. |
9 |
Metric 2 Value Format Code |
String |
Y |
Value format code for second metric. |
10 |
Metric 2 Max Threshold |
Number |
N |
Metric 2 values greater than the Metric 2 Max Threshold value will be displayed in Green. |
11 |
Metric 2 Min Threshold |
Number |
N |
Metric 2 values less than the Metric 2 Min Threshold value will be displayed in Red. |
12 |
Metric 3 Name |
String |
Y |
Column header label for third metric. |
13 |
Metric 3 Value Format Code |
String |
Y |
Value format code for third metric. |
14 |
Metric 3 Max Threshold |
Number |
N |
Metric 3 values greater than the Metric 3 Max Threshold value will be displayed in Green. |
15 |
Metric 3 Min Threshold |
Number |
N |
Metric 3 values less than the Metric 3 Min Threshold value will be displayed in Red. |
BI Table Item
0 |
Image URL |
String |
N |
URL of image to display |
1 |
Descriptor 1 Value |
String |
Y |
Value for first descriptor. |
2 |
Descriptor 2 Value |
String |
N |
Value for second descriptor. |
3 |
Metric 1 Value |
Number |
Y |
Value for first metric. |
4 |
Metric 2 Value |
Number |
N |
Value for second metric. |
5 |
Metric 3 Value |
Number |
N |
Value for third metric. |
BI Report Analyses
This section describes the required analyses for each report and will reference the BI Response Layout above for details.
BI Two Metric Report
This category includes the following report template:
BI Two Metric Summary
Table A-3 Required Analysis
| Template Parameter | Response Layout | Repeat within row | Rows | Columns |
BI Analysis Catalog Location |
BI Simple Metric |
up to 2 |
1 |
4 to 8 |
BI Twelve Metric Report
Table A-4 Required Analysis
BI Metric |
Up to 12 |
1 |
5 to 6 |
BI Metric Chart Reports
This category includes the following report templates:
BI Four Metric with Chart Template
BI Six Metric with Chart Template
Table A-5 Required Analyses
BI Metrics Analysis Catalog Location |
BI Metric |
up to 4/6 |
1 |
5 to 20/30 |
BI Chart Configuration Analysis Catalog Location |
BI Metric Chart Config |
No |
1 |
13 |
BI Chart Items Analysis Catalog Location |
BI Metric Chart Item |
No |
Many |
2 |
BI Table Reports
BI Metrics Table Template
BI Image Table Template
BI Image Metrics Template
Table A-6 Required Analyses
BI Table Headers Analysis Catalog Location |
BI Table Config |
No |
1 |
up to 16 |
BI Table Items Analysis Catalog Location |
BI Table Item |
No |
Many |
up to 6 |
All the report templates listed above require the same analyses using the same column layout, but some columns are not used in some reports. The BI Metrics Table Template will ignore the image related columns. The BI Image Table Template will ignore the values and configuration for the second and third metrics. If ignored columns are at the end of the row (such as metrics) they can be left out of the response.
