Configuring the Data Visualizer Template
The data visualizer template allows embedding data visualization from Retail Insights in an expanded report.
The catalog reference is retrieved in the same way as for the BI tile states. The default view of the data visualizer report can be controlled using the optional active page and tab ID values. Refer to the Data Visualizer documentation on embedded views for more information on what values to enter for these.
The Data Visualizer expanded view will open the report in Data Visualizer in a new tab.
