4 User Interface
The DDS UI is divided into two sections; Admin tab, and Designer tab. The Admin tab lets admin users control access and perform security operations. The Designer tab lets admin, operators and monitor users perform authorized functions.
This chapter explains the main UI functionality available to the user.
Admin Tab Guide
This tab has all the functions for configuring security related permissions and user access. Only the admin user has access to this tab. The admin can enable read, write and modify access permissions and also limit functionality of a user.
The Admin Tab has three main sections:
Manage Access Levels
Manage Security Groups
Manage Security permissions
Initial Permissions Setup
In order to access the data on tables being viewed in the Designer Tab, first the Table level securities have to be setup in the Admin tab of the DDS Application. The Admin can select the desired database schema from the associated database schema dropdown.
Access to this tab is only allowed to the Admin User.
This tab allows the creation and deletion of Access Levels for data and functionality. These can be assigned to groups for particular tables in a schema.
To create an access level
Input a name in the Name text box.
Select the necessary access permissions.
Click Create.
To delete an access level
Select the Access Level to be deleted from the table which displays the available access levels.
Click Delete.
This tab includes functionality for the creation and deletion of Security Groups. Security Groups are groups of users that have a certain level of data access. These, along with one or more access levels, can be assigned to a table to limit access to data and functionality in the Designer tab.
To create a Security Group
Click Create.
To delete a Security Group
Select the Security Group to be deleted from the table that displays the available Security Groups.
Click Delete.
Manage Security Permissions
This tab allows the user to create and delete Security Permissions. Security Permissions are a combination of one or more Access levels in a Security Group mapped to a table to restrict data access and also limit functionality, like removing the ability to create, modify or delete data.
To create a Security Permission for a table
In the Create TableLevelSecurities collapsible pane, select the desired table.
Then select the required security group.
Finally select the required access level(s).
Click Create.
To delete Security Permission(s)
Functionality is provided to either perform bulk delete or individual deletion of security.
To bulk delete security permissions:
Select the required table name(s) or security group(s) or access level(s).
Click Delete.
To individually delete security permissions:
Select the required table name.
Select the particular security group associated.
Select the associated access level.
Click Delete.
Designer Tab Guide
This tab contains all the CRUD operations to be performed by user on tables in the database schema. The user can select the desired database schema available in the database schema dropdown. It has two sections:
Table Definition
Query Builder
Make sure the user has sufficient permissions before performing any action in the designer tab.
Table Definition
This tab allows the user to see the basic definition of the Database table in a simplified format presented in a tabular form.
To view a table's definition, select the required table from the list of tables from the left pane of the screen. Clicking on the table name will load the definition on the display screen under the Table Definition tab.
![table definition table definition](img/table-def1.png)
Query Builder
This tab holds the functionality for data manipulation. Functions include Querying records to creation, modification and deletion of records.
Data Selection
To Query records from a table:
Select the table from the list of tables on the left pane of the screen.
Enable join if the join operation is necessary.
Select the table to which the join is to be done, select the same table as selected in (1) to do a self-join.
Select the columns which are to be displayed in the column filter. Only the column names on the right side of the box will be displayed. If all columns are to be displayed, do not move any columns to the right box.
Select the row filter.
The row filter is applied only to the first two columns in the table, so reorder the columns such that the ones that have to be used as row filter are in the two positions.
Set the page limit, this is the number of records that are to be displayed on one page, the remaining records will be paginated and displayed upon request.
The Sort by drop down list works if there are columns selected for a column filter. Select the desired column, and then select the sort order, ascending or descending.
Click on the run button
to get the Query results using the settings configured earlier.
The reset button
sets the settings back to default.
The copy query button
is used to copy the GET query generated in the "GET" box. Click on the button and the link is copied. Paste the link in a browser and press enter/return to execute the query.
Data Insertion
To insert the data in the table:
The query results from the GET call are displayed here in an editable tabulated format.
To insert a record click on the insert record button
In the pop-up, enter the data. Make sure to enter all values for not null columns.
Click Insert.
The record will be successfully inserted after validation.
Data Modification
To modify existing data, select the data from desired table.
Double click on the record to be modified
Edit the contents
Press escape on the keyboard to exit edit mode and click on the save button
to save the changes.
Message - Record updated successfully will be displayed after validation
Bulk Updations of Data
The option is available to update bulk records on selected data. To bulk update column(s):
In the bulk update collapsible pane one or more columns for all records in the queried table can be updated with a single value, if the column is not unique.
Select the checkbox of the required column to enable edit mode.
Enter the data as necessary.
Click the Bulk Update option
to update the selected columns for all the records in the table.
Records will be updated after successful validation of data.
Data Deletion
This option is available to perform individual and bulk deletions of records.
Individual Delete - To delete a single record, click the delete button on the corresponding record.
Bulk Delete -To delete all records, click the delete all button and confirm once the confirmation dialog pops up.
The number of records deleted message will be displayed upon successful deletion of records.
![number of records deleted number of records deleted](img/records-deleted.png)
