B Process Flow REST Endpoints
The endpoint "discover" can be used to identify all endpoints provided by Process Flow.
| REST Resource | HTTP Method | Description |
/discover |
GET |
Lists all available endpoints |
/batch/processes/enable-disable |
POST |
Enable or disable process flows |
/batch/processes/operator/{processName} |
POST |
Start a new Process Flow execution |
/batch/processes/executions/{processName} |
GET |
List Process Executions for the process name |
/batch/processes/executions |
GET |
List all process execution ids |
/batch/processes/executions/status/{status} |
GET |
List all process execution ids for the specified status |
/batch/processes/executions/time/{startTime}/{endTime} |
GET |
List all process execution ids for the specified time range |
/batch/processes/external-variables |
GET |
List external variables |
PUT |
Create external variables |
POST |
Update external variables |
/batch/processes/external-variables/{key} |
DELETE |
Delete external variable |
/batch/processes/currently-running-processes |
GET |
List all the currently running process flows |
/batch/processes |
GET |
Get all the available process definitions |
/batch/processes/{processName} |
GET |
Get process DSL for the specified process |
/batch/processes/executions/{processName}/{processExecutionId}/activities/{activityExecutionId} |
GET |
Get all the activities for the process flow execution |
/batch/processes/{processName}/activities |
GET |
Get all the activities for the process specified |
/batch/processes/operator/{processName}/{processExecutionId} |
POST |
Restart a process execution instance |
/batch/processes/operator/{processName}/resolve |
POST |
Resolves stranded process by setting the status of process to PROCESS_FAILED |
/batch/processes/{processName}/{processExecutionId} |
DELETE |
Stops running process |
DELETE |
Stops all running processes |
/batch/processes/{processName}/activities/{activityName} |
POST |
Sets skip, hold flags for activity. Query parameters that can be passed with this end point - "skip", "hold", "actionExpiryDate", "comments". |
GET |
Returns dynamic configuration for activity |
/telemetry/processes |
GET |
Returns process runtime metrics between fromTime and toTime |
