C System Setting Service
The System Setting service is a RESTful service available in all BDI apps (Job Admin and Process Flow) that provides endpoints to manage system option parameters and credentials to be used by the BDI apps. The system options are stored in the BDI_SYSTEM_OPTIONS table.
| REST Resource | HTTP Method | Description |
/system-setting/system-options |
GET |
Gets all system options from BDI_SYSTEM_OPTIONS table |
PUT |
Creates a system option in BDI_SYSTEM_OPTIONS table. Only admin user is allowed to perform this operation. |
POST |
Updates a system option in BDI_SYSTEM_OPTIONS table. Only admin user is allowed to perform this operation. |
/system-setting/system-options/{key} |
DELETE |
Deletes a system option from BDI_SYSETM_OPTIONS table. Only admin user is allowed to perform this operation. |
GET |
Gets a system option from BDI_SYSTEM_OPTIONS table |
/system-setting/system-logs |
GET |
Gets system logs |
/system-setting/system-seed-data |
GET |
Gets system seed data file |
/system-setting/system-seed-data/reset-after-bounce |
POST |
Resets system seed data after bounce |
/system-setting/system-seed-data/reset-now |
POST |
Resets system seed data now |
/system-setting/system-credentials |
GET |
Gets system credentials. Only admin user is allowed to perform this operation. |
PUT |
Creates system credentials. Only admin user is allowed to perform this operation. |
POST |
Updates system credentials. Only admin user is allowed to perform this operation. |
/system-setting/system-credentials/{key} |
DELETE |
Deletes system credentials. Only admin user is allowed to perform this operation. |
/system-setting/reset-cache |
POST |
Resets system option cache |
Managing System Options using curl
Here are examples of curl commands to list/create/update/delete system options for Process Flow. These commands can be run for Job Admin as well. Create/update/delete commands can only be run by administrator.
Create system option
This command creates "reimappJobAdminBaseUrlUserAlias" system option in Process Flow.
curl --user userId:password -i -X PUT -H "Content-Type:application/json" http://server:port/bdi-process-flow/resources/system-setting/system-options -d '{"key":"reimappJobAdminBaseUrlUserAlias" , "value":" GET_FROM_WALLET:GET_FROM_WALLET "}'
Update system option
This command updates "reimappJobAdminBaseUrl" system option in Process Flow.
curl --user userId:password -i -X POST -H "Content-Type:application/json" http://server:port/bdi-process-flow/resources/system-setting/system-options -d '{"key":"reimappJobAdminBaseUrl" , "value":"http://server:port/reim-batch-job-admin"}'
Managing credentials using curl
Here are examples of curl commands to list/create/update/delete credentials for Process Flow. These commands can be run for Job Admin as well. Create/update/delete commands can only be run by administrator.
Create credential
This command creates a credential in Process Flow.
curl --user userId:password -i -X PUT -H "Content-Type:application/json" http://server:port/bdi-process-flow/resources/system-setting/system-credentials -d '{"userAlias":" reimappJobAdminBaseUrlUserAlias", "userName":"reimjobadmin" , "userPassword":"xyzxyz"}'
Update credential
This command updates a credential in Process Flow.
curl --user userId:password -i -X POST -H "Content-Type:application/json" http://server:port/bdi-process-flow/resources/system-setting/system-credentials -d '{"userAlias":" reimappJobAdminBaseUrlUserAlias", "userName":"reimjobadmin" , "userPassword":"wwwqqqq"}'
