D Sample Extractor - PL/SQL application code that calls procedures in PL/SQL package
BEGIN
-- First call beginDataSet of the corresponding interface module datactl pkg before loading data to interface tables.
-- Here interfacemodule is Diff_Fnd and dataload is full set. If partial dataset, then call beginPartialSet_Diff_Fnd
IF Diff_Fnd_Out_DataCtl.beginFullSet_Diff_Fnd(O_datacontrol_id,O_error_message) = 0 THEN
DBMS_OUTPUT.PUT_LINE('interfaceModuleDataControlId: ' || O_datacontrol_id);
ELSE
DBMS_OUTPUT.PUT_LINE('beginFullSet_Diff_Fnd error: ' || O_error_message);
Return;
END IF;
-- Call application PL/SQL package to populate outbound interface table
-- Then call endDataSet of the corresponding interface module datactl pkg
IF Diff_Fnd_Out_DataCtl.onSuccEndSet_Diff_Fnd(O_datacontrol_id,O_error_message) = 0 THEN
DBMS_OUTPUT.PUT_LINE('Successfully called onSuccEndSet');
COMMIT;
ELSE
DBMS_OUTPUT.PUT_LINE('onSuccEndSet error: ' || O_error_message);
ROLLBACK;
END IF;
EXCEPTION
WHEN OTHERS
THEN
Call onErrDiscardSet in case of an error
IF Diff_Fnd_Out_DataCtl.onErrDiscardSet_Diff_Fnd(O_datacontrol_id,O_error_message) = 0 THEN
DBMS_OUTPUT.PUT_LINE('Successfully called onErrEndSet');
ELSE
DBMS_OUTPUT.PUT_LINE('onErrEndSet error: ' || O_error_message);
END IF;
END;
