A Appendix: Integrating BDI-RMS with External Applications
This section provides guideline for integrating External application with RMS using BDI.
Installation Instructions
Additional entries are to be added in BDI-RMS configuration file to integrate bdi-rms with bdi-external.
Copy the Job xmls from: bdi-edge-rms-job-home/setup-data/available-jobs-for-external-app-integration to the folder bdi-edge-rms-job-home/setup-data/META-INF/batch-jobs/.
cd bdi-edge-rms-job-home/setup-data/ cp available-jobs-for-external-app-integration/*.* META-INF/batch-jobs/
Install bdi-edge-rms application by following instructions in the section Deploying BDI RMS Batch Job Admin on the WebLogic.
