5 Process Flow Installation
Prerequisites
The Process Flow application has the same tech stack requirements mentioned in the beginning of this document for JDK, WebLogic domain, and database. Before installing the Process Flow application install the following infrastructure components for the application.
A WebLogic domain with JRF for the application
A database schema for the Process Flow application
Before you begin installing BDI Process Flow, make sure you have the database schema created for BDI Process flow.
If you are migrating from previous version of BDI PROCESS FLOW to a newer version, Follow upgrade instructions for bdi. Before following upgrade instructions for bdi, you need to provide permissions for database schema. Run the below commands on admin schema where database schema is created, to provide permissions.
Commands:
CREATE TABLE TO 'user schema'; CREATE SEQUENCE TO 'user schema'; CREATE INDEX TO 'user schema';
Example: User schema name is bdi_process_app. Run below commands on admin schema.
CREATE TABLE TO 'bdi_ process _app'; CREATE SEQUENCE TO 'bdi_ process _app'; CREATE INDEX TO 'bdi_ process _app';
The recommended java VM memory setting for the Process Flow application domain is:
-Xms1024m -Xmx2048m
Install the Process Flow Application
Perform the following procedure to install the Process Flow application:
Download the process flow archive BdiProcessFlow24.0.000ForAll23.x.xApps_eng_ga.zip
Unzip the downloaded archive. The Process Home directory will be created under the current directory.
unzip BdiProcessFlow24.0.000ForAll23.x.xApps_eng_ga.zip
This command extracts the archive. The relevant directories for the installation are shown below (There are more directories than what is shown).
| |- - - - - - - bin | ` - - - - - - bdi-process-flow-admin-deployer.sh |- - - - - - - conf | ` - - - - - - bdi-process-flow-admin-deployment-env-info.json | ` - - - - - - bdi-process-flow-admin-internal-trust-store.jks | ` - - - - - - log4j2.xml | ` - - - - - - security | ` - - - - - - jazn-data.xml | ` - - - - - - jps-config.xml |- - - - - - - dist | ` - - - - - - bdi-process-flow-24.0.000.war | ` - - - - - - README.txt |- - - - - - - lib |- - - - - - - scripts | ` - - - - - - DBSchemaMigration.groovy | ` - - - - - - ProcessFlowAdminDeployer.groovy | ` - - - - - - README.txt | ` - - - - - - WebLogicManager.groovy |- - - - - - - setup-data | ` - - - - - - ddl | | |- - - - - - - - - migration | | | |- - - - - - - - - BDI_Database_Util_Spec_Permission.sql | | | |- - - - - - - - - BDI_Database_Util_Spec.sql | | | |- - - - - - - - - create_wl_llr_table.sql | | | |- - - - - - - - - migrate-process-schema-from-16.0.027-to-16.0.028.sql | | | |- - - - - - - - - migrate-schema-from-16.0.021-to-16.0.023.sql | | | |- - - - - - - - - migrate-schema-from-16.0.023-to-16.0.025.sql | | | |- - - - - - - - - migrate-schema-from-16.0.025-to-16.0.027.sql | | | |- - - - - - - - - migrate-schema-from-16.0.031-to-19.0.000.sql | | | |- - - - - - - - - migrate-schema-from-16.0.21-to-16.0.023.sql | | |- - - - - - - - - purge | | |- - - - - - - - - purge_process_repo.sql | ` - - - - - - dml | ` - - - - - - dsl | ` - - - - - - available_process_flow_options | | |- - - - - - - - - enterprise-sender_side_split_flows | | |- - - - - - - - - rms_enterprise-sender_side_split_flows | | |- - - - - - - - - rms_external-no_split_flows | | |- - - - - - - - - rms_rfi-no_split_flows |- - - - - - - target | ` - - - - - - bdi-process-flow.war | ` - - - - - - README.txt
Modify process flow configuration file(conf/bdi-process-flow-admin-deployment-env-info.json) to match the deployment environment and to support OAuth2 feature. The deployment description json format has changed from previous release, to accommodate IDCS client credentials and URL.While you can change many values to match your requirements, here is a table of a minimum set of configuration values that you need to modify for process flow application.
To deploy without OAuth, we need to remove or replace the OAuth2 aliases (For example:- jobAdminUiOAuth2ApplicationClientAliasRef) in bdi-process-flow-admin-deployment-env-info.json, and then deploy. No other extra steps required for deployment.
The alias names in the configuration files should not be changed.
Configuration Field Description BdiProcessFlowAdminDataSource ->jdbcUrl
JDBC URL for the process flow schema. Change this value to match the environment
ProcessFlowAdminAppServer ->weblogicDomainName
Name of the WebLogic domain where the process flow application is deployed
ProcessFlowAdminAppServer ->weblogicDomainHome
WebLogic Domain home directory
ProcessFlowAdminAppServer- > weblogicDomainProtocol
WebLogic admin server protocol is by default t3, if SSL configured then update to t3s.
ProcessFlowAdminAppServer ->weblogicDomainAdminServerUrl
WebLogic Admin server URL
ProcessFlowAdminAppServer ->weblogicDomainAdminServerHost
Host name of WebLogic Admin Server
ProcessFlowAdminAppServer ->weblogicDomainAdminServerPort
WebLogic admin server port
ProcessFlowAdminAppServer ->weblogicDomainTargetManagedServerName
Managed Server name where Process Flow is hosted
ProcessFlowAdminAppServer ->processFlowAdminUiUrl
Process Flow admin app URL. Update only the host and port
RmsAppJobAdminAppServer-->jobAdminUiUrl
BDI RMS job admin URL
RfiAppJobAdminAppServer-> jobAdminUiUrl
RFIAPP job admin URL
ExternalAppJobAdminAppServer
BDI EXTERNAL job admin URL
oauth2AuthorizationServerUrl
IDCS URL
For example: https://idcs-4ff493196128425c80ce4ecbfc8352e5.identity.c9dev1.oc9qadev.com/oauth2/v1/token
SystemOptions
allAvailableDestinationApps mentions all the apps available as destination
appsInScope - mentions the apps that are in scope.
Example:
ProcessFlow JSON Snippet:
"ProcessFlowAdminApplication":{ "ProcessFlowAdminAppUses":[ "ProcessFlowAdminDataSource", "ProcessFlowAdminAppServer", { "RemoteJobAdminAppServers":[ "RfiAppJobAdminAppServer", "RmsAppJobAdminAppServer", "ExternalAppJobAdminAppServer" ] } ], "SystemOptions":[ {"name":"allAvailableDestinationApps", "value":"EXTERNAL,RFI,RMS"}, {"name":"appsInScope", "value":" RFI"}, {"name":"jobGroupCacheEnabled", "value":"false"}, {"name":"flowSelection.1.pattern", "value":"_From_EXTERNAL"}, {"name":"flowSelection.1.initialState", "value":"false"}, {"name":"flowSelection.2.pattern","value":"ProcessFlowName1,ProcessFlowName2"}, {"name":"flowSelection.2.initialState", "value":"true"}, {"name":"skipImporterActivitiesForExternal", "value":"true"}, {"name":"repave_notification_lead_time", "value":"30"}, {"name":"processFlowNotification.global.enable", "value":"false"}, {"name":"processFlowNotification.global.onStart", "value":"false"}, {"name":"processFlowNotification.global.onRestart", "value":"false"}, {"name":"processFlowNotification.global.onFailure", "value":"true"}, {"name":"processFlowNotification.global.onCompletion", "value":"false"} ] }
Process Flow Json snippet for OAuth support:
"CentralAuthenticationSystem":{ "IdcsAuthenticationProvider":{ "oauth2AuthorizationServerUrl":"https://idcs-4ff493196128425c80ce4ecbfc8352e5.identity.c9dev1.oc9qadev.com/oauth2/v1/token", "oauth2Application":[ { "oauth2ApplicationName" : "RICS", "oauth2ApplicationScopeOfAccess" : {"name":"oauth2.default.scopeOfAccess.*", "value":"urn:opc:idm:__myscopes__"}, "oauth2ApplicationClientAlias" : "ric-sOauth2ApplicationClientAlias", "oauth2ApplicationClientId" : "GET_FROM_WALLET", "oauth2ApplicationClientSecret" : "GET_FROM_WALLET" }, { "oauth2ApplicationName" : "MFCS", "oauth2ApplicationScopeOfAccess" : {"name":"oauth2.default.scopeOfAccess.*", "value":"urn:opc:idm:__myscopes__"}, "oauth2ApplicationClientAlias" : "mfcsO-auth2ApplicationClientAlias", "oauth2ApplicationClientId" : "GET_FROM_WALLET", "oauth2ApplicationClientSecret" : "GET_FROM_WALLET" } ] }, "OamAuthenticationProvider":{ }
BDI Process flow installer copies all the enterprise flows from bdi-process-home/setup-data/dsl/available_process_flow_options/rms_enterprise-sender_side_split_flows/ to bdi-process-home/setup-data/dsl/flows-in-scope.
Configure the appsInScope system options in process flow configuration file. As shown in step 3 above.
If you are migrating from previous version to a new version, follow the upgrade instructions for bdi.
Run the deployer. Make sure that the WebLogic server is running before issuing the following command.
cd bin bdi-process-flow-admin-deployer.sh -setup-credentials -deploy-process-flow-admin-app
The process flow deployer will prompt for username and password for the following credential aliases:
Alias Description bdiAppServerAdminServerUserAlias
WebLogic admin server credentials
processFlowAdminBaseUrlUserAlias
Credentials for Admin Role user for Process Flow Admin app
processFlowOperatorBaseUrlUserAlias
Credentials for Operator Role user for Process Flow Admin app
processFlowMonitorBaseUrlUserAlias
Credentials for Monitor Role user for Process Flow Admin app
bdiProcessFlowAdminDataSourceUserAlias
Credentials for the Data Source of the Process Flow Schema
rmsappJobAdminBaseUrlUserAlias
RMS job admin credentials
externalappJobAdminBaseUrlUserAlias
External job admin credentials
rfiappJobAdminBaseUrlUserAlias
RFIAPP job admin credentials
IDCS Client ID and password
(name":"rmsappJobAdminBaseUrlOAuth2ApplicationClientAlias", "value": "*mfcsOauth2ApplicationClientAlias)
(name":"rfiappJobAdminBaseUrlOAuth2ApplicationClientAlias", "value": "*ricsOauth2ApplicationClientAlias)
If you have an existing process flow deployment then, login to Process Flow App, go to Manage Configurations -> System Options and update the following system options before running the above command. LOADPROCESSDEF = TRUE and LOADSEEDDATA = TRUE
Value "skipImporterActivitiesForExternal' cannot be updated using System Options available in UI. It can be done by updating its value in bdi-process-flow-admin-deployment-env-info.json and redeploying application.
Set value of "skipImporterActivitiesForExternal' to false for on premise users.
Example: {"name":"skipImporterActivitiesForExternal","value":"false"}
If you have already configured various credentials required for process flow, you can run the deployer with the following syntax. It will not ask the credentials again for the deployment. Make sure you set the LOADPROCESSDEF = true, LOADSEEDDATA = true.
bdi-process-flow-admin-deployer.sh -use-existing-credentials -deploy-process-flow-admin-app
Make sure the deployment step shows deployment success message at the end.
Restrict access to the bdi-process-home folder:
cd bdi-process-home chmod -R 700 .
Bounce the process managed server.
Verify Installation
If the process flow app is successfully deployed, you should be able to access the application at the URL http://<host>:<port>/bdi-process-flow/. The following is a sample screenshot of the process flow application. Make sure all the tabs of the application are properly displayed.
See the Oracle Retail Bulk Data Integration Implementation Guide for the operation details of the Process Flow application.
Enabling Email Notification Alerts
Process Flow can send email alerts upon success or failure of process executions as specified in the process definitions. The following configuration is required for process email notification.
Mail Session configuration in WebLogic, for process email notification:
Go to the WebLogic Admin console of the environment where the process app is deployed.
Navigate to Services -> Mail Sessions.
Select New to create a new mail session.
Enter the following details:
JNDI name: mail/BdiProcessMailSession
Session Username: A valid email id, preferably email-id of an administrator.
Session password: The password for the above email id.
Enter the following in the JavaMail properties:
mail.smtp.ssl.enable=true
mail.smtp.auth=true
mail.smtp.ssl.trust=<company's smtp mail server host name>
mail.smtp.port=<mail server smtps port, typically is 465>
mail.transport.protocol=smtps
mail.smtp.host=<company's smtp mail server host name>
mail.from=<A valid email-id for 'from email address' when email is sent>
mail.to(Optional)=<List of valid recipients email-ids>
Web Session Mail.to property is used if processFlowNotification.<scope>.recipients is not set in Process Notification Configuration.
Click Next. In the Mail Session Targets, select the managed server where the process application is deployed.
Finish creating the mail session.
For more information on configuring Mail sessions on WebLogic, see the Oracle® WebLogic Administrator's Guide 12c Release.
Repave lead time by default is 30. The user can modify the value through System Options repave_notification_lead_time.
Process Flow Upgrade Steps
Download the BdiProcessFlow24.0.000ForAll23.x.xApps_eng_ga.zip from RTG Wiki and extract.
Take the backup of existing bdi-process-home.
Cd to bdi-process-home/conf folder.
Modify process flow configuration file (conf/bdi-process-flow-admin-deployement-env-info.json) to match the deployment environment and support OAuth2 feature.
The deployment description json format has changed from previous release, to accom-modate IDCS client credentials and URL.
"oauth2AuthorizationServerUrl":"https://idcs-4ff493196128425c80ce4ecbfc8352e5.identity.c9dev1.oc9qadev.com/oauth2/v1/token" ? Replace with IDCS server url
Login to the existing deployed process flow app.
Go to Manage Configurations -> System Options and make following changes: LOADPROCESSDEF = TRUE and LOADSEEDDATA = TRUE
Delete the existing process flow app.
Run the below command to upgrade and deploy the process-flow-app.
Cd bin sh bdi-process-flow-admin-deployer.sh -use-existing-credentials -run-db-schema-migration -deploy-process-flow-admin-app
BDI process flow installer copies all the enterprise flows from process-home/setup-data/dsl/available_process_flow_options/rms_enterprise-sender_side_split_flows/ to process-home/setup-data/dsl/flows-in-scope while deployment.
After successful deployment, bounce the managed server.
