Location Group Scope View: Rule Group
The Location Group Scope View, under the Location Group Scope tab, allows you to select the specific locations to be included in the rule group.
Figure 7-15 Location Group Scope View: Rule Group
Location Group Scope View: Rule Group - Default Profile Measures
The Location Group Scope view contains the following measures.
LOC Group Scope
Location Group Scope is a checkbox measure used to select which locations should be assigned to the databag.
LOC Group Assoc.
Location Group Associated is a calculated measure that indicates whether the location groups are associated with the rule group or not. The measure is selected if the location groups are associated. If the location groups are not associated, it is clear.
