Source Scope View
The Source Scope View, under the Source Scope tab, allows you to select specific source locations to be included in the rule group.
Figure 7-16 Source Scope View
Source Scope View
Source Scope View - Default Profile Measures
The Source Scope view contains the following measures.
SLOC Scope
Source Location Scope is a checkbox measure used to select which source locations should be assigned to the rule group.
SLOC Assoc.
Source Location Associated is a calculated measure that indicates whether the source locations are associated with the rule group or not. The measure is selected if the source locations are associated. If the source locations are not associated, it is clear.
