C Appendix: IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Scheduling in JOS/POM
IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment provides a default job schedule with a detailed list of jobs with pre-defined dependencies with RI and AIF schedules in RAP integration. The customer can easily customize their batch process by controlling the batch control files without changing the batch schedule. Each batch job in IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment is connected to hooks in the batch control files that can be changed by customers. The IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment job flow only contains daily and weekly jobs. Jobs scheduled daily are scheduled to run every day and jobs scheduled to run weekly are scheduled to run only on Sunday by default.
Table C-1shows the list of jobs in IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Schedule. Most jobs are pre-configured for the IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment GA version. The rest of the jobs are placeholder jobs to allow changes to the schedule of the jobs or to add more jobs by changing the batch control file. Each IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment job calls the same set names in the batch control file without _JOB in the name, which in turn allows it to call respective *hook_ jobs, so even if it is not linked to a batch set. The batch can be controlled without changing the job flow by adding or changing the hooks.
For more details about the implementation of JOS/POM, see the Oracle Retail Predictive Application Server Cloud Edition Implementation Guide. For more details about how to use JOS/POM to schedule and maintain the job flows, see the Oracle Retail JOS/POM User Guide.
Table C-1 List of Jobs in IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Schedule
IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Job Name Description/Comments Daily/Weekly GA Configuration
IPO_INIT_EXP_START_JOB
Dummy Job to specify the start of initial batch exports.
Daily
IPO_INIT_EXP_RDX_D_JOB
To schedule any daily data exports to RAP integration before the calc cycle.
Daily
IPO_ INIT_EXP_OBS_D_JOB
To schedule any daily data exports to Object Storage before the calc cycle.
Daily
IPO_ INIT_EXP_RDX_W_JOB
To schedule any weekly data exports to RAP integration before the calc cycle.
Weekly
IPO_ INIT_EXP_OBS_W_JOB
To schedule any weekly data exports to Object Storage before the calc cycle.
Weekly
IPO_ INIT_EXP_END_JOB
Dummy job to specify the end of initial batch exports.
Daily
IPO_COM_HIER_IMP_ START_JOB
Dummy job to specify the start of a common hierarchies import.
Daily
IPO_COM_HIER_IMP_ RDX_D_JOB
To schedule any daily common hierarchy imports from RAP integration.
Daily
Imports common hierarchies from RI.
IPO_COM_HIER_IMP_OBS_ D_JOB
To schedule any daily common hierarchy imports from Object Storage.
Daily
Loads common hierarchy files from Object Storage, if uploaded.
IPO_COM_HIER_IMP_ RDX_W_JOB
To schedule any weekly common hierarchy imports from RAP integration.
Weekly
IPO_COM_HIER_IMP_OBS_ W_JOB
To schedule any weekly common hierarchy imports from Object Storage.
Weekly
IPO_COM_HIER_IMP_ END_JOB
Dummy Job, to specify the end of a common hierarchies import.
Daily
IPO_COM_DATA_IMP_ START_JOB
Dummy job to specify the start of common data imports.
Daily
IPO_COM_DATA_IMP_ RDX_D_JOB
To schedule any daily common data imports from RAP integration.
Daily
IPO_COM_DATA_IMP_ OBS_D_JOB
To schedule any daily common data imports from Object Storage.
Daily
IPO_COM_DATA_IMP_ RDX_W_JOB
To schedule any weekly common data imports from RAP integration.
Weekly
IPO_COM_DATA_IMP_ OBS_W_JOB
To schedule any weekly common data imports from Object Storage.
Weekly
IPO_COM_DATA_IMP_ END_JOB
Dummy job to specify the end of common data imports.
Daily
IPO_HIER_IMP_START_JOB
Dummy job to specify the start of application-specific hierarchies import.
Daily
IPO_HIER_IMP_RDX_D_ JOB
To schedule any daily application-specific hierarchy imports from RAP integration.
Daily
Imports application-specific hierarchies from RI or AIF.
IPO_HIER_IMP_OBS_D_ JOB
To schedule any daily application-specific hierarchy imports from Object Storage.
Daily
Load any Application specific hierarchies from Object Storage.
IPO_HIER_IMP_RDX_W_ JOB
To schedule any weekly application-specific hierarchy imports from RAP integration.
Weekly
IPO_HIER_IMP_OBS_W_ JOB
To schedule any weekly application-specify hierarchy imports from Object Storage.
Weekly
IPO_HIER_IMP_END_JOB
Dummy job to specify the end of application-specific hierarchies import.
Daily
IPO_PRE_DATA_IMP_ START_JOB
Dummy job to specify the start of application-specific data imports before the calc cycle.
Daily
IPO_PRE_DATA_IMP_RDX_ D_JOB
To schedule any daily application-specific data imports from RAP integration before the calc cycle.
Daily
Imports application-specific data from RI or AIF.
IPO_PRE_DATA_IMP_OBS_ D_JOB
To schedule any daily application-specific data imports from Object Storage before the calc cycle.
Daily
Load any application specific data from Object Store.
IPO_PRE_DATA_IMP_RDX_ W_JOB
To schedule any weekly application-specific data imports from RAP integration before the calc cycle.
Weekly
IPO_PRE_DATA_IMP_OBS_ W_JOB
To schedule any weekly application-specific data imports from Object Storage before the calc cycle.
Weekly
IPO_PRE_DATA_IMP_ END_JOB
Dummy Job to specify the end of application-specific data imports before the calc cycle.
Daily
IPO_PRE_BATCH_START_ JOB
Dummy job to specify the start of the Pre Forecast Batch.
Daily
IPO_PRE_BATCH_D_JOB
To schedule any daily Pre Forecast batch jobs.
Daily
IPO_PRE_BATCH_W_JOB
To schedule any weekly Pre Forecast batch jobs.
Weekly
Runs Weekly Pre Forecast batch jobs.
IPO_PRE_BATCH_END_ JOB
Dummy job to specify the end of the Pre Forecast batch jobs.
Daily
IPO_PRE_EXP_START_JOB
Dummy job to specify the start of the Export Forecast Parameters Batch.
Daily
IPO_PRE_EXP_RDX_D_JOB
To schedule any daily exports of forecast parameters to RAP integration.
Daily
IPO_PRE_EXP_OBS_D_JOB
To schedule any daily exports of forecast parameters to object store.
Daily
IPO_PRE_EXP_RDX_W_JOB
To schedule any weekly exports of forecast parameters to RAP integration.
Weekly
Runs weekly export of forecast parameters to RAP integration.
IPO_PRE_EXP_OBS_W_JOB
To schedule any weekly exports of forecast parameters to object store.
Weekly
IPO_PRE_EXP_END_JOB
Dummy job to specify the end of the Export Forecast Parameters Batch.
Daily
IPO_EGRS_EXP_START_JOB
IPO Egress Exports Start Job
Daily
IPO_EGRS_EXP_RDX_D_JOB
IPO Egress Exports to RDX Daily Job
Daily
IPO_EGRS_EXP_RDX_W_JOB
IPO Egress Exports to RDX Weekly Job
Weekly
IPO_EGRS_EXP_END_JOB
IPO Egress Exports End Job
Daily
IPO_POST_DATA_IMP_ START_JOB
Dummy job to specify the start of application-specific data imports from RAP integration.
Daily
IPO_POST_DATA_IMP_ RDX_D_JOB
To schedule any daily application-specific data imports from RAP integration after the calc cycle.
Daily
IPO_POST_DATA_IMP_ OBS_D_JOB
To schedule any daily application-specific data imports from Object Storage after the calc cycle.
Daily
IPO_POST_DATA_IMP_ RDX_W_JOB
To schedule any weekly application-specific data imports from RAP integration after the calc cycle.
Weekly
Imports forecast data from AIF.
IPO_POST_DATA_IMP_ OBS_W_JOB
To schedule any weekly application-specific data imports from Object Storage after the calc cycle.
Weekly
IPO_POST_DATA_IMP_ END_JOB
Dummy Job, to specify the end of application-specific data imports after the calc cycle.
Daily
IPO_POST_BATCH_START_JOB
Dummy Job, to specify the start of Post Forecast batch job.
Daily
IPO_POST_BATCH_D_JOB
To schedule the daily Post Forecast batch job.
Daily
Runs daily post forecast batch jobs.
IPO_POST_BATCH_W_JOB
To schedule the weekly Post Forecast batch job.
Weekly
Runs weekly post forecast batch jobs
IPO_POST_BATCH_END_JOB
Dummy Job, to specify the end of Post Forecast batch job.
Daily
IPO_BATCH_ID_1_JOB
IPO Batch Intra-Day 1 Job
Daily
IPO_BATCH_ID_2_JOB
IPO Batch Intra-Day 2 Job
Daily
IPO_POST_EXP_START_JOB
Dummy Job to specify the start of post forecast batch exports.
Daily
IPO_POST_EXP_RDX_D_ JOB
To schedule any daily data exports to RAP integration after the calc cycle.
Daily
Runs daily exports.
IPO_POST_EXP_OBS_D_ JOB
To schedule any daily data exports to Object Storage after the calc cycle.
Daily
IPO_POST_EXP_RDX_W_ JOB
To schedule any weekly data export to RAP integration after the calc cycle.
Weekly
Runs weekly exports.
IPO_POST_EXP_OBS_W_ JOB
To schedule any weekly data exports to Object Storage after the calc cycle.
Weekly
IPO_POST_EXP_END_JOB
Dummy job to specify the end of post forecast batch exports.
Daily
IPO_WB_BUILD_START_ JOB
Dummy job to specify the start of workbook build/refresh jobs.
Daily
IPO_WB_BUILD_D_JOB
To schedule any workbook build/refresh steps daily.
Daily
Runs daily dashboard updates.
IPO_WB_BUILD_W_JOB
To schedule any workbook build/refresh steps weekly.
Weekly
Runs weekly dashboard updates.
IPO_WB_BUILD_END_JOB
Dummy job to specify the end of workbook build/refresh jobs.
Daily
IPO_ADHOC_XX_JOB
To schedule any adhoc jobs with the batch execution set name as a parameter. XX varies from 01 to 10.
Adhoc
IPO_STATS_START_JOB
Dummy job to specify start of Offer metric server job.
Weekly
IPO_STATS_OFFER_W_JOB
Server level job to get Offer metric status.
Weekly
IPO_STATS_END_JOB IPO
Dummy job to specify end of Offer metric server job.
Weekly
