Viewing and Editing Quantities
The View/Edit Allocation Detail screen displays the results of the system's calculation. From here, you can:
- Review Calculated Quantities: Analyze the system-recommended Allocated Qty for each item/destination.
- Manually Adjust Quantities: Enter a new value in the Manual Qty column to override the system's recommendation. This gives you precise control over the final distribution.
