Approving the Allocation
When you are satisfied with the final quantities:
Click the Edit icon in the header to open the details panel.
Change the Allocation Status from Worksheet to Approved.
Click the Save button.
This final action will lock the allocation from further edits and automatically trigger its export to your merchandising and warehouse management systems for execution.
