Rule Value
Rule value defines the target or threshold for the rule. It sets the specific action or limit that the rule will enforce.
Example rule values:
Margin - Minimum margin of 30%
Budget - Maximum budget of $50,00,000
Exit Date - 30/09/2023
Promotion Range - Between 15% to 40% for first promotion and 10% to 25% for subsequent promotions
Figure 4-3 Rule Criteria and Value - Markdown and Promotion
