Update Note
When you enter a note using abbreviations or short cuts (or even typos), you can select Generate, which make a GenAI call to expand or elaborate on the note, whenever possible.
Figure 7-24 Update Note
This image shows update note
Figure 7-25 Update Note Generate
This image shows update note generate.
