C Appendix: Regular - Manage Recommendations
The following table uses the official Manage Recommendations appendix column-heading format and keeps the Rules Based Regular Pricing columns that are relevant to recommendation review and action.
Table C-1 C-1 Column Details
Column Heading Default Definition DB Reference / Calculation
Flag Y Users can flag the recommendation for further review. PRO_RUN_RECOM_OPT_RESULT.FCST_REVIEW_CODE
Notes Y Users can enter comments for the recommendation. PRO_RUN_RECOM_OPT_RESULT.FCST_NOTE
Ovrd Status Y Shows whether the item has any pending recalculation and which user requested it. PRO_RUN_RECOM_OPT_RESULT.CHANGED_BY_USER
Item / Product Hierarchy Y External code, name, and description for the item and product hierarchy levels. CONCAT(RSE_PROD_HIER.PROD_EXT_CODE, '-', RSE_PROD_HIER.NAME)
Item Descr Y Item description, external code, and name shown in separate columns. RSE_PROD_HIER.DESCR
Brand Name Y Brand name for the item. RSE_PROD_GRP.NAME
Price Zone Y Price zone of the item recommendation. Corresponds to the run setup level. RSE_PRICE_ZONE and RSE_PRICE_ZONE_GRP
Location Hierarchy Y Chain, area, region, district, or location hierarchy values. Not applicable when price zones are used. RSE_LOC_HIER_DH
Rec Status Y Recommendation status of the item, such as Ready for Review, Reviewed, Approved, Submitted, or Export Failed. PRO_RUN_RECOM_OPT_RESULT.RECOMMENDATION_STATUS_ID joined with PRO_RECOMMENDATION_STATUS
Season Y Season, such as Fall 2024 Merchandise. PRO_SEASON.NAME
Rec Price Y Recommended price of the item. PRO_RUN_RECOM_OPT_RESULT.RECOM_PRICE
Rec Type Y Recommendation type of the item, such as Regular or No Recommendation. PRO_RUN_RECOM_OPT_RESULT.PRICE_RECOM_TYPE_ID joined with PRO_PRICE_RECOM_TYPE
Run Id and Name Y ID and name of the optimization run that generated the recommendation. CONCAT(PRO_RUN_HDR.ID, '-', PRO_RUN_HDR.NAME)
Optimization Date Y Date of optimization run. PRO_RUN_HDR.LAST_EXECUTION_DATE
Recalculation Date Y Date when the item was recalculated. PRO_RUN_RECOM_OPT_RESULT.RECALCULATE_DT
Recalculation User Y User who last requested the recalculation. PRO_RUN_RECOM_OPT_RESULT.RECALCULATE_BY_USER
Exported On Date Y Date when the item was exported after approval. PRO_RUN_RECOM_OPT_RESULT.EXPORTED_ON_DT
Approved By User Y User who approved the recommendation. PRO_RUN_RECOM_OPT_RESULT.EXPORTED_BY_USER
Ovrd Price N Overridden price for the item. PRO_RUN_RECOM_OPT_RESULT.USR_OVRD_RECOM_PRICE
Ovrd Price Type N Override price type for the item. PRO_RUN_RECOM_OPT_RESULT.USR_OVRD_PRICE_RECOM_TYPE_ID joined with PRO_PRICE_RECOM_TYPE
Max Competitor Price N Maximum competitor price for the item-location. PRO_REG_RUN_RECOM_OPT_RESULT.MAX_COMPETITOR_PRICE
Min Competitor Price N Minimum competitor price for the item-location. PRO_REG_RUN_RECOM_OPT_RESULT.MIN_COMPETITOR_PRICE
Avg Competitor Price N Average competitor price for the item-location. PRO_REG_RUN_RECOM_OPT_RESULT.AVG_COMPETITOR_PRICE
Most Common Competitor Price N Most common competitor price for the item-location. PRO_REG_RUN_RECOM_OPT_RESULT.MCV_COMPETITOR_PRICE
Product Attribute 1 - 5 N Product attributes selected by the user in the filter, such as Brand. RSE_PROD_ATTR
Currency Attribute 1 - 30 Y User-defined attribute of currency type. Flex Fact (W_RTL_FLEX_FACT)
Date Attribute 1 - 15 Y User-defined attribute of date type. Flex Fact (W_RTL_FLEX_FACT)
Number Attribute 1 - 40 Y User-defined attribute of number type. Flex Fact (W_RTL_FLEX_FACT)
Percentage Attribute 1 - 15 Y User-defined attribute of percentage type. Flex Fact (W_RTL_FLEX_FACT)
