B Appendix: Regular - Run Overview
This table provides information about table columns and calculations for Regular Optimization runs.
Table B-1 B-1 Column Details
Column Heading Default Definition DB Reference / Calculation
Run Id Y System-generated unique identifier for the run. RUN_HDR_ID
Finalized Y Flag indicating that recommendations from the run are finalized and used in Manage Recommendations. FINALIZED_FLG
Run Name Y User provided name for the run. RUN_NAME
Run Description Y User provided description for the run. RUN_DESCR
Department Y A description of the Department. CONCAT(PROD_HIER_EXT_CODE, '-', PROD_HIER_NAME)
Price Zone Group Y Price zone group of the item recommendation. Corresponds to the run setup level. CONCAT(PRICE_ZONE_GRP_EXT_CODE, '-', PRICE_ZONE_GRP_NAME)
Price Zone Y Price zone of the item recommendation. Corresponds to the run setup level. CONCAT(PRICE_ZONE_EXT_CODE, '+', PRICE_ZONE_NAME)
Company Y Location of the item recommendation, such as Region or Channel. Will be chain when using price zones. CONCAT(LOC_HIER_EXT_CODE, '+', LOC_HIER_NAME)
Opt Start Dt Y The start date of optimization. START_CAL_FROM_DT
Opt End Dt Y The end date of optimization. END_CAL_TO_DT
Strategy Y The strategy used for optimization. It can be DEFAULT STRATEGY or another custom strategy. RULE_SET_NAME
Total Item Cnt Y Total item count. ITEM_OPTIMIZED_COUNT
Non-fcst Item Cnt Y Number of non-forecast item recommendations included in the run. NON_FCST_ITEM_CNT
No Rec Item Cnt Y Total items that are in No Recommendation status. ITEM_NOREC_COUNT
Reg Item Cnt Y Regular items count. ITEM_REGULAR_COUNT
User Ovrd Item Cnt Y Total items that are overridden by user. ITEM_USR_OVRD_COUNT
Run Status Y Status of the run. RUN_STATUS_DESCR
Optimized On Y The date when the run was optimized. LAST_EXECUTION_DATE
Modified By Y Login ID of the user who modified the run. CHANGED_BY_USER
Created By Y Login ID of the user who created the run. CREATED_BY_USER
Created Date Y The date when the run was first created. CREATED_ON_DT
