Cost Change Purge (ccprg)
Module Name |
ccprg.pc |
Description |
Purge Aged Cost Changes |
Functional Area |
Cost Change |
Module Type |
Admin |
Module Technology |
ProC |
Catalog ID |
RMS476 |
Wrapper Script |
rmswrap.ksh |
Design Overview
This program is responsible for removing old cost changes from the system. Cost changes are removed from the system using the following criteria:
The status of the cost change is either Delete or Canceled.
The status of the cost change is Rejected and the effective date of the cost change has met the requirement for the number of days that rejected cost changes are held.
The status of the cost change is Extracted and the effective date of the cost change has met the requirement for the number of days that extracted cost changes are held.
The number of days that rejected cost changes are held is determined by the system parameter Retention of Rejected Cost Changes (RETENTION_OF_REJECTED_COST_CHG). The number of days that extracted cost changes are held is determined by the system parameter Retention of Extracted Cost Changes (RETN_EXTRACTED_COST_CHG).
