Cost Change Purge (cost_change_purge_job)
Module Name |
cost_change_purge_job |
Description |
Purge Aged Cost Changes |
Functional Area |
Cost Change |
Module Type |
Admin - Ad hoc |
Module Technology |
Background Processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of two-step processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from cost change header table based on its purge criteria from system parameter settings. The Retention of Rejected Cost Changes parameter will determine the number of days that rejected cost changes are held. The Retention of Extracted Cost Changes parameter will determine the number of days extracted cost changes are held. It also should meet the following criteria:
The status of the cost change is either Delete or Canceled.
The status of the cost change is Rejected and the effective date of the cost change has met the requirement for the number of days that rejected cost changes are held.
The status of the cost change is Extracted and effective date of the cost change has met the requirement for the number of days that extracted cost changes are held.
These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from cost change header and other related cost change tables. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Key Tables Affected
Table 8-1 Key Tables Affected
| Table | Select | Insert | Update | Delete |
PERIOD |
Yes |
No |
No |
No |
PURGE_CONFIG_OPTIONS |
Yes |
No |
No |
No |
RMS_BATCH_STATUS |
Yes |
No |
No |
No |
B8D_PROCESS_CONFIG |
Yes |
No |
No |
No |
JOB_AUDIT_LOGS |
No |
Ys |
No |
No |
B8D_COST_CHANGE_PURGE_STG |
Yes |
Yes |
No |
Yes |
COST_SUSP_SUP_HEAD |
Yes |
No |
No |
Yes |
COST_SUSP_SUP_DETAIL |
Yes |
No |
No |
Yes |
COST_SUSP_SUP_DETAIL_LOC |
Yes |
No |
No |
Yes |
