Calculate Totals Based on Client Defined Rules (sa_totals_calc_job)
Module Name |
sa_totals_calc_job |
Description |
Calculate Totals based on Client Defined Rules |
Functional Area |
Sales Audit, Totals |
Module Type |
Admin - Ad hoc |
Module Technology |
Background Processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from the Sales Audit Store/Day table for all stores wherein auditing status is "Re-Totaling/Auditing Required". Totaling provides the values against which auditors can compare receipts. These comparisons find data errors that could be the result of either honest mistakes or fraud. Finding these mistakes during the sales auditing process prevents these errors from being passed on to merchandising and data warehouse systems. Totaling also provides quick access to other numeric figures about the day's sales transactions.
Totaling in Sales Audit is dynamic. Sales Audit automatically totals transactions based on calculation definitions that the retailer's users create using the online Totals Calculation Definition Wizard. In addition, the retailer is able to define totals that come from the POS but that Sales Audit does not calculate. Whenever users create new calculation definitions or edit existing ones, they become part of the automated totaling process the next time that this program runs. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will process the records for totals build-up and calculation by calling SA_BUILD_TOTAL_SQL.PROCESS_CALC_TOTALS for each store day captured. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Key Tables Affected
Table 19-1 Key Tables Affected
Table | Select | Insert | Update | Delete |
RMS_BATCH_STATUS |
Yes |
No |
No |
No |
B8D_PROCESS_CONFIG |
Yes |
No |
No |
No |
JOB_AUDIT_LOGS |
No |
Yes |
No |
No |
B8D_SA_TOTALS_CALC_STG |
Yes |
Yes |
No |
Yes |
SA_STORE_DAY |
Yes |
No |
Yes |
No |
SA_TOTAL |
No |
Yes |
No |
No |
SA_TOTAL_HEAD |
Yes |
No |
No |
No |
SA_ERROR |
No |
Yes |
No |
Yes |
SA_ERROR_WKSHT |
No |
Yes |
No |
Yes |
SA_POS_VALUE |
No |
Yes |
No |
No |
SA_POS_VALUE_WKSHT |
No |
Yes |
No |
No |
SA_SYS_VALUE |
No |
Yes |
No |
No |
SA_SYS_VALUE_WKSHT |
No |
Yes |
No |
No |
SA_ERROR_REV |
No |
Yes |
No |
No |
SA_EXPORTED_REV |
No |
Yes |
No |
No |
SA_EXPORTED |
No |
No |
No |
Yes |
