Calculate Weekly/Monthly Income Based on Turnover (dealinc)
Module Name |
dealinc.pc |
Description |
Calculate Weekly/Monthly Income Based on Turnover |
Functional Area |
Deals |
Module Type |
Business Processing |
Module Technology |
ProC |
Catalog ID |
RMS211 |
Wrapper Script |
rmswrap.ksh |
Design Overview
This program generates income for each item/location for bill-back deals.
Dealinc.pc retrieves deal attributes and actuals data from the deals tables for complex deals. It then calculates the income and will update the actuals table with the calculated income value. Additionally the program will insert the income value into the TEMP_TRAN_DATA table using the tran types deal sales and deal purchases.
Subsequent programs will run to perform forecast processing for active deals and to roll up TEMP_TRAN_DATA rows inserted by the multiple instances of this module and insert/update DAILY_DATA with the summed values and then insert details from TEMP_TRAN_DATA into TRAN_DATA. Income is calculated by retrieving threshold details for each deal component and determining how to perform the calculation (that is, Linear/Scalar, Actuals Earned/Pro-Rate).
