Calculates/Update Forecasted Values for Deals (dealfct)
Module Name |
dealfct.pc |
Description |
Calculates/Update Forecasted Values for Deals |
Functional Area |
Deals |
Module Type |
Business Processing |
Module Technology |
ProC |
Catalog ID |
RMS209 |
Wrapper Script |
rmswrap_multi.ksh |
Design Overview
This program aggregates income for each item/location and recalculates forecasted values. It maintains forecast periods, deal component totals and deal totals.
After determining which active deals need to have forecast periods updated with actuals, the program will then sum up all the actuals for the deal reporting period and update the table with the summed values and change the period from a forecast period to a fixed period. The program will also adjust either the deal component totals or the remaining forecast periods to ensure that the deal totals remain correct. For each deal, the program will also maintain values held at header level.
