Detail Receive Damaged or Tampered with Cartons (tamperctn)
Module Name |
tamperctn.pc |
Description |
Detail Receive Damaged or Tampered with Cartons |
Functional Area |
Transfers, Allocations and RTVs |
Module Type |
Business Processing |
Module Technology |
ProC |
Catalog ID |
RMS371 |
Wrapper Script |
rmswrap.ksh |
Design Overview
This program looks for items that were intended to be received as a pack and attempts to match based on component quantity. It reads records from the staging table for the carton ID for pack items not received and attempts to match on the components of the pack and quantity. If a match is found, then the dummy carton is received against the matching carton. If a match is not found, an error is written to an error file and the record remains on the staging table. These unprocessed records are eventually purged from the staging table when the receipt transaction date is older than the current date minus Close Open Shipments After.
This program is only run if the Receive Pack Component system parameter is set to Yes.
