Prevent Duplicate Export of Total Values from ReSA (sapreexp)
Module Name |
sapreexp.pc |
Description |
Prevent Duplicate Export of Total Values from Sales Audit |
Functional Area |
Oracle Retail Sales Audit |
Module Type |
Admin |
Module Technology |
ProC |
Catalog ID |
RSA20 |
Wrapper Script |
rmswrap.ksh |
Design Overview
When you modify or revise a transaction through the Sales Audit user application, numerous totals may be affected and require re-totaling. The sales audit pre-export module is designed to compare the latest prioritized version of each total defined for export with the version that was previously sent to each system. If they are the same, an SA_EXPORTED entry is created for the total for that particular system, so that the same value will not be exported twice. By determining which totals have not changed since the last export date time (SA_EXPORTED_REV), this module will then create entries on SA_EXPORTED to prohibit any third-party application from receiving multiple export revisions.
