Process Pending Merchandise Hierarchy Changes from External Systems (cremhierdly)
Module Name |
cremhierdly.pc |
Description |
Process Pending Merchandise Hierarchy Changes from External Systems |
Functional Area |
Foundation Data |
Module Type |
Business Processing |
Module Technology |
ProC |
Catalog ID |
RMS204 |
Runtime Parameters |
rmswrap.ksh |
Design Overview
This batch program reads merchandise hierarchy records from the pending merchandise hierarchy table whose effective date is tomorrow or earlier. The pending merchandise hierarchy table is populated by the Merchandise Hierarchy Reclass Subscription API. Each record is then used to either insert or update existing merchandise hierarchy data in Merchandising based on the action and hierarchy types. The inserted/updated records are deleted from the pending merchandise hierarchy table after they have been successfully processed.
This program is only required if updates to the merchandise hierarchy in Merchandising are being managed outside the application.
