Purge Aged Purchase Orders (order_purge_job)
Module Name |
order_purge_job |
Description |
Purge Aged Purchase Orders |
Functional Area |
Purchase Orders |
Module Type |
Admin - Ad hoc |
Module Technology |
Background Processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of two-step processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from order header and other associated and order-related tables based on its conditions below:
If importing is not enabled in the system (as defined by the import system indicator = 'N') and if invoice matching is not installed, then all details associated with an order are deleted when the order has been closed for more months than specified in 'Order History Months' purge parameter. Orders will only be deleted if all allocations associated, if any, have been closed.
If invoice matching is installed, then all details associated with an order are deleted when the order has been closed for more months than specified in the 'Order History Months' purge parameter. Orders are deleted only if allocations associated have been closed, shipments from the order have been completely matched to invoices or closed, and all those invoices have been posted.
If importing is enabled in the system (as defined by the import system indicator = 'Y') and if invoice matching is not installed, then all details associated with the order are deleted when the order has been closed for more months than specified in the 'Order History Months' purge option. This action presupposes that all ALC records associated with an order are in 'Processed' status, specified in the ALC header and allocations associated to the order, if any, have been closed.
If invoice matching is installed, then all details associated with an order are deleted when the order has been closed for more months than specified in the 'Order History Months' purge parameter. This action presupposes that all ALC records associated with an order are in 'Processed' status, specified in ALC head, all allocations associated to the order, if any, have been closed, all shipments from the order have been completely matched to invoices or closed, and all those invoices have been posted.
If the order to be purged is an import PO and it doesn't have a letter of credit (LC) then purge the related records related to obligations, ALC and ICB transfers.
These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from order header and other associated and order-related tables. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Key Tables Affected
Table 5-3 Key Tables Affected
Table | Select | Insert | Update | Delete |
PURGE_CONFIG_OPTIONS |
Yes |
No |
No |
No |
RMS_BATCH_STATUS |
Yes |
No |
No |
No |
B8D_PROCESS_CONFIG |
Yes |
No |
No |
No |
JOB_AUDIT_LOGS |
No |
Yes |
No |
No |
B8D_ORDER_PURGE_STG |
Yes |
Yes |
No |
Yes |
ORDHEAD |
Yes |
No |
No |
Yes |
ORDLC |
Yes |
No |
No |
No |
ALLOC_HEADER |
Yes |
No |
No |
Yes |
SHIPMENT |
Yes |
No |
No |
Yes |
SHIPSKU |
Yes |
No |
Yes |
Yes |
INVC_HEAD |
Yes |
No |
No |
Yes |
ORDLOC_REV |
No |
No |
No |
Yes |
ORDHEAD_REV |
No |
No |
No |
Yes |
ALLOC_REV |
No |
No |
No |
Yes |
ALC_HEAD |
Yes |
No |
No |
Yes |
ALC_COMP_LOC |
No |
No |
No |
Yes |
OBLIGATION_COMP_LOC |
No |
No |
No |
Yes |
OBLIGATION_COMP |
No |
No |
No |
Yes |
OBLIGATION |
No |
No |
No |
Yes |
TRANSPORTATION |
Yes |
No |
No |
Yes |
MISSING_DOC |
No |
No |
No |
Yes |
TRANS_PACKING |
No |
No |
No |
Yes |
TRANS_DELIVERY |
No |
No |
No |
Yes |
TRANS_CLAIMS |
No |
No |
No |
Yes |
TRANS_LIC_VISA |
No |
No |
No |
Yes |
TRANS_SKU |
No |
No |
No |
Yes |
CE_ORD_ITEM |
Yes |
No |
No |
Yes |
CE_LIC_VISA |
No |
No |
No |
Yes |
CE_CHARGES |
No |
No |
No |
Yes |
CE_SHIPMENT |
No |
No |
No |
Yes |
CE_PROTEST |
No |
No |
No |
Yes |
CE_FORMS |
No |
No |
No |
Yes |
CE_HEAD |
v |
No |
No |
Yes |
APPT_HEAD |
Yes |
No |
No |
Yes |
APPT_DETAIL |
Yes |
No |
No |
Yes |
DOC_CLOSE_QUEUE |
No |
No |
No |
Yes |
DAILY_PURGE |
No |
Yes |
No |
No |
ORDSKU |
Yes |
No |
No |
Yes |
ITEM_MASTER |
Yes |
No |
No |
No |
PACKITEM |
Yes |
No |
No |
No |
PACK_TMPL_HEAD |
Yes |
No |
No |
No |
RTV_DETAIL |
No |
No |
No |
Yes |
WO_DETAIL |
No |
No |
No |
Yes |
CARTON |
No |
No |
No |
Yes |
WO_HEAD |
Yes |
No |
No |
Yes |
ALLOC_CHRG |
No |
No |
No |
Yes |
ALLOC_DETAIL |
No |
No |
No |
Yes |
TIMELINE |
No |
No |
No |
Yes |
ORDLOC |
No |
No |
No |
Yes |
ORDLOC_DISCOUNT |
No |
No |
No |
Yes |
ORDLOC_EXP |
No |
No |
No |
Yes |
ORDSKU_HTS_ASSESS |
No |
No |
No |
Yes |
ORDSKU_HTS |
No |
No |
No |
Yes |
REQ_DOC |
No |
No |
No |
Yes |
ORDSKU_REV |
No |
No |
No |
Yes |
ORDLOC_INVC_COST |
No |
No |
Yes |
Yes |
ORDCUST |
Yes |
No |
No |
Yes |
ORDCUST_DETAIL |
No |
No |
No |
Yes |
ORDCUST_CUSTOMER_DETAIL |
No |
No |
No |
Yes |
ORD_XDOCK_TEMP |
No |
No |
No |
Yes |
INVC_XREF |
No |
No |
No |
Yes |
INVC_MATCH_WKSHT |
No |
No |
No |
Yes |
ORDLOC_WKSHT |
No |
No |
No |
Yes |
SUP_VIOLATION |
No |
No |
No |
Yes |
REV_ORDERS |
No |
No |
No |
Yes |
LC_ORDAPPLY |
No |
No |
No |
Yes |
ORDHEAD_DISCOUNT |
No |
No |
No |
Yes |
RUA_RIB_INTERFACE |
No |
No |
No |
Yes |
ORDLOC_TEMP |
No |
No |
No |
Yes |
ALLOC_CHRG_TEMP |
No |
No |
No |
Yes |
ALLOC_DETAIL_TEMP |
No |
No |
No |
Yes |
ALLOC_HEADER_TEMP |
No |
No |
No |
Yes |
ORDSKU_TEMP |
No |
No |
No |
Yes |
ORDLOC_EXP_TEMP |
No |
No |
No |
Yes |
ORDSKU_HTS_ASSESS_TEMP |
No |
No |
No |
Yes |
ORDSKU_HTS_TEMP |
No |
No |
No |
Yes |
ORDLOC_DISCOUNT_TEMP |
No |
No |
No |
Yes |
TIMELINE_TEMP |
No |
No |
No |
Yes |
REQ_DOC_TEMP |
No |
No |
No |
Yes |
WO_DETAIL_TEMP |
No |
No |
No |
Yes |
WO_HEAD_TEMP |
No |
No |
No |
Yes |
REPL_RESULTS_TEMP |
No |
No |
No |
Yes |
DEAL_COMP_PROM |
No |
No |
No |
Yes |
DEAL_HEAD |
Yes |
No |
No |
Yes |
DEAL_THRESHOLD |
No |
No |
No |
Yes |
DEAL_DETAIL |
No |
No |
No |
Yes |
DEAL_QUEUE |
No |
No |
No |
Yes |
ORD_INV_MGMT |
No |
No |
No |
Yes |
REPL_RESULTS |
No |
No |
No |
Yes |
INVC_DETAIL |
No |
No |
No |
Yes |
INVC_NON_MERCH |
No |
No |
No |
Yes |
INVC_MERCH_VAT |
No |
No |
No |
Yes |
INVC_DETAIL_VAT |
No |
No |
No |
Yes |
INVC_DISCOUNT |
No |
No |
No |
Yes |
INVC_TOLERANCE |
No |
No |
No |
Yes |
INVC_MATCH_QUEUE |
No |
No |
No |
Yes |
TSFHEAD |
No |
No |
No |
Yes |
TSFDETAIL |
No |
No |
No |
Yes |
TSFDETAIL_CHRG |
No |
No |
No |
Yes |
DEAL_ITEMLOC_ITEM |
No |
No |
No |
Yes |
DEAL_ITEMLOC_DCS |
No |
No |
No |
Yes |
DEAL_ITEMLOC_DIV_GRP |
No |
No |
No |
Yes |
DEAL_ITEMLOC_PARENT_DIFF |
No |
No |
No |
Yes |
ORDHEAD_L10N_EXT |
No |
No |
No |
Yes |
ORD_TAX_BREAKUP |
No |
No |
No |
Yes |
ORDHEAD_CFA_EXT |
No |
No |
No |
Yes |
DEALHEAD_CFA_EXT |
No |
No |
No |
Yes |
TSFHEAD_CFA_EXT |
No |
No |
No |
Yes |
SHIPSKU_LOC_PRG_HIST |
No |
Yes |
No |
No |
SHIPSKU_PRG_HIST |
No |
Yes |
No |
No |
SHIPMENT_PRG_HIST |
No |
Yes |
No |
No |
ALLOC_CHRG_PRG_HIST |
No |
Yes |
No |
No |
ALLOC_DETAIL_PRG_HIST |
No |
Yes |
No |
No |
ALLOC_HEADER_PRG_HIST |
No |
Yes |
No |
No |
ORDLOC_REV_PRG_HIST |
No |
Yes |
No |
No |
ORDSKU_REV_PRG_HIST |
No |
Yes |
No |
No |
ORDHEAD_REV_PRG_HIST |
No |
Yes |
No |
No |
ORDCUST_DETAIL_PRG_HIST |
No |
Yes |
No |
No |
ORDCUST_PRG_HIST |
No |
Yes |
No |
No |
ORDLOC_CFA_EXT_PRG_HIST |
No |
Yes |
No |
No |
ORDLOC_PRG_HIST |
No |
Yes |
No |
No |
ORDLOC_DISCOUNT_PRG_HIST |
No |
Yes |
No |
No |
ORDLOC_EXP_PRG_HIST |
No |
Yes |
No |
No |
ORDSKU_HTS_ASSESS_PRG_HIST |
No |
Yes |
No |
No |
ORDSKU_HTS_PRG_HIST |
No |
Yes |
No |
No |
ORDSKU_CFA_EXT_PRG_HIST |
No |
Yes |
No |
No |
ORDSKU_PRG_HIST |
No |
Yes |
No |
No |
ORDHEAD_DISCOUNT_PRG_HIST |
No |
Yes |
No |
No |
ORDHEAD_L10N_EXT_PRG_HIST |
No |
Yes |
No |
No |
ORD_TAX_BREAKUP_PRG_HIST |
No |
Yes |
No |
No |
ORDHEAD_CFA_EXT_PRG_HIST |
No |
Yes |
No |
No |
ORDHEAD_PRG_HIST |
No |
Yes |
No |
No |
