Purge Closed Deals Actuals Item/Location (deal_actuals_purge_job)
Module Name |
deal_actuals_purge_job |
Description |
Purge Closed Deals |
Functional Area |
Deals |
Module Type |
Admin - Ad hoc |
Module Technology |
Background Processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of two-step processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from complex deal header and deal actuals forecast tables based on updated last invoice date that were processed beyond the current date. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from either deal actuals item-location table only. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Key Tables Affected
Table 6-3 Key Tables Affected
Table | Select | Insert | Update | Delete |
DEAL_HEAD |
Yes |
No |
No |
No |
RMS_BATCH_STATUS |
Yes |
No |
No |
No |
B8D_PROCESS_CONFIG |
Yes |
No |
No |
No |
JOB_AUDIT_LOGS |
No |
Yes |
No |
No |
B8D_DEAL_ACTUALS_PURGE_STG |
Yes |
Yes |
No |
No |
DEAL_ACTUALS_ITEM_LOC |
No |
No |
No |
Yes |
DEAL ACTUALS_FORECAST |
Yes |
No |
No |
No |
