Purge Closed Deals (dealprg)
Module Name |
dealprg.pc |
Description |
Purge Closed Deals |
Functional Area |
Deals |
Module Type |
Admin |
Module Technology |
ProC |
Catalog ID |
RMS212 |
Wrapper Script |
rmswrap.ksh |
Design Overview
The purpose of this batch program is to purge deals after they have been held in the system for the specified number of history months after they are closed. The number of months of history is defined in the PURGE_CONFIG_OPTIONS table in the DEAL_HISTORY_MONTHS column.
The batch program will also delete deal performance tables based on the specified number of history months. This program will not cover PO-specific deals, which will be purged with the PO.
