Purge Into History Tables (b8d_sa_purge)
Module Name |
b8saprgb.pls/ b8saprgs.pls |
Description |
Purge records into History tables |
Functional Area |
Financial data |
Module Type |
Admin - Ad hoc |
Module Technology |
Background Processing |
Catalog ID |
N/A |
Wrapper Script |
b8dwrap.ksh |
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records based on the Store/Day, Sales Audit System Options, and Period tables. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process records from the base tables based on Store Day Sequence Number, Store, and Business Day. Using bulk processing, this program will filter the records from the tables and insert the records into the history tables. Then the inserted records will be deleted from the base tables.
The decision to insert or not to insert the records into the history tables is based on the Archive Indicator and Archive Job Indicator from the Background Process Configuration table.
If the both the Archive Indicator and Archive Job Indicator values are Y, then the data from the base tables are inserted into the history tables.
If both indicators are set to 'N', then the records are deleted from the base tables without inserting into the history tables.
Key Tables Affected
Table | Select | Insert | Update | Delete |
PERIOD |
Yes |
No |
No |
No |
SYSTEM_OPTIONS |
Yes |
No |
No |
No |
RMS_BATCH_STATUS |
Yes |
No |
No |
No |
B8D_PROCESS_CONFIG |
Yes |
No |
No |
No |
B8D_SA_PURGE_STG |
No |
Yes |
No |
No |
ALL_PART_TABLES |
Yes |
No |
No |
No |
SA_COMMENTS_HIST |
No |
Yes |
No |
No |
SA_CUSTOMER_HIST |
No |
Yes |
No |
No |
SA_CUST_ATTRIB_HIST |
No |
Yes |
No |
No |
SA_ERROR_HIST |
No |
Yes |
No |
No |
SA_ERROR_REV_HIST |
No |
Yes |
No |
No |
SA_EXPORTED_HIST |
No |
Yes |
No |
No |
SA_EXPORTED_REV_HIST |
No |
Yes |
No |
No |
SA_EXPORT_LOG_HIST |
No |
Yes |
No |
No |
SA_FLASH_SALES_HIST |
No |
Yes |
No |
No |
SA_HQ_VALUE_HIST |
No |
Yes |
No |
No |
SA_IMPORT_LOG_HIST |
No |
Yes |
No |
No |
SA_MISSING_TRAN_HIST |
No |
Yes |
No |
No |
SA_POS_VALUE_HIST |
No |
Yes |
No |
No |
SA_STORE_DAY_HIST |
No |
Yes |
No |
No |
SA_STORE_VALUE_HIST |
No |
Yes |
No |
No |
SA_SYS_VALUE_HIST |
No |
Yes |
No |
No |
SA_TOTAL_HIST |
No |
Yes |
No |
No |
SA_TRAN_DISC_HIST |
No |
Yes |
No |
No |
SA_TRAN_DISC_REV_HIST |
No |
Yes |
No |
No |
SA_TRAN_HEAD_HIST |
No |
Yes |
No |
No |
SA_TRAN_HEAD_REV_HIST |
No |
Yes |
No |
No |
SA_TRAN_IGTAX_HIST |
No |
Yes |
No |
No |
SA_TRAN_IGTAX_REV_HIST |
No |
Yes |
No |
No |
SA_TRAN_ITEM_HIST |
No |
Yes |
No |
No |
SA_TRAN_ITEM_REV_HIST |
No |
Yes |
No |
No |
SA_TRAN_PAYMENT_HIST |
No |
Yes |
No |
No |
SA_TRAN_PAYMENT_REV_HIST |
No |
Yes |
No |
No |
SA_TRAN_TAX_HIST |
No |
Yes |
No |
No |
SA_TRAN_TAX_REV_HIST |
No |
Yes |
No |
No |
SA_TRAN_TENDER_HIST |
No |
Yes |
No |
No |
SA_TRAN_TENDER_REV_HIST |
No |
Yes |
No |
No |
SA_COMMENTS |
Yes |
No |
No |
Yes |
SA_CUSTOMER |
Yes |
No |
No |
Yes |
SA_CUST_ATTRIB |
Yes |
No |
No |
Yes |
SA_ERROR |
Yes |
No |
No |
Yes |
SA_ERROR_REV |
Yes |
No |
No |
Yes |
SA_EXPORTED |
Yes |
No |
No |
Yes |
SA_EXPORTED_REV |
Yes |
No |
No |
Yes |
SA_EXPORT_LOG |
Yes |
No |
No |
Yes |
SA_FLASH_SALES |
Yes |
No |
No |
Yes |
SA_HQ_VALUE |
Yes |
No |
No |
Yes |
SA_IMPORT_LOG |
Yes |
No |
No |
Yes |
SA_MISSING_TRAN |
Yes |
No |
No |
Yes |
SA_POS_VALUE |
Yes |
No |
No |
Yes |
SA_STORE_DAY |
Yes |
No |
No |
Yes |
SA_STORE_VALUE |
Yes |
No |
No |
Yes |
SA_SYS_VALUE |
Yes |
No |
No |
Yes |
SA_TOTAL |
Yes |
No |
No |
Yes |
SA_TRAN_DISC |
Yes |
No |
No |
Yes |
SA_TRAN_DISC_REV |
Yes |
No |
No |
Yes |
SA_TRAN_HEAD |
Yes |
No |
No |
Yes |
SA_TRAN_HEAD_REV |
Yes |
No |
No |
Yes |
SA_TRAN_IGTAX |
Yes |
No |
No |
Yes |
SA_TRAN_IGTAX_REV |
Yes |
No |
No |
Yes |
SA_TRAN_ITEM |
Yes |
No |
No |
Yes |
SA_TRAN_ITEM_REV |
Yes |
No |
No |
Yes |
SA_TRAN_PAYMENT |
Yes |
No |
No |
Yes |
SA_TRAN_PAYMENT_REV |
Yes |
No |
No |
Yes |
SA_TRAN_TAX |
Yes |
No |
No |
Yes |
SA_TRAN_TAX_REV |
Yes |
No |
No |
Yes |
SA_TRAN_TENDER |
Yes |
No |
No |
Yes |
SA_TRAN_TENDER_REV |
Yes |
No |
No |
Yes |
SA_CUSTOMER |
Yes |
No |
No |
Yes |
SA_POS_VALUE_WKSHT |
Yes |
No |
No |
Yes |
SA_SYS_VALUE_WKSHT |
Yes |
No |
No |
Yes |
SA_ERROR_WKSHT |
Yes |
No |
No |
Yes |
SA_STORE_ACH |
Yes |
No |
No |
Yes |
SA_ESCHEAT_VOUCHER |
Yes |
No |
No |
Yes |
SA_ESCHEAT_TOTAL |
Yes |
No |
No |
Yes |
KEY_MAP_GL |
Yes |
No |
No |
Yes |
SA_GL_REF_DATA |
Yes |
No |
No |
Yes |
SA_STORE_DAY_WRITE_LOCK |
Yes |
No |
No |
Yes |
