Recalculate Maximum Levels for Floating Point Replenishment (repladj)
Module Name |
repladj.pc |
Description |
Recalculate Maximum Levels for Floating Point Replenishment |
Functional Area |
Replenishment |
Module Type |
Business Processing |
Module Technology |
ProC |
Catalog ID |
RMS307 |
Wrapper Script |
rmswrap_multi.ksh |
Design Overview
This batch module recalculates the maximum stock levels for all item-location combinations with replenishment method of 'F' (floating point). The floating model stock method will dynamically calculate an order-up-to-level. The calculated order-up-to-level is used to update the item/location replenishment table.
The maximum model stock (used for calculating order-up-to-level) is derived using the sales history of various periods of time in order to accommodate seasonality as well as trend. The sales history is obtained from the item/location history table.
